Ca II K3 Prominences - 3rd Jan 2022
- Has thanked: 174 times
- Been thanked: 619 times
An exciting collection of proms visible this morning - MiniSHG Ca II K.
Enjoy!!
Enjoy!!
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
Re: Ca II K3 Prominences - 3rd Jan 2022
Really nice image Ken - and amazing capture of CaK prominence activity!
- Has thanked: 17853 times
- Been thanked: 16992 times
WoW! These are among the best images of prominences I have seen in CaK!!
Thanks guys, appreciate.
These were taken in Ca II K3 (central wavelength) resolution about 0.18A.
Processed with Matt's version of INTI
No additional processing or enhancement - as is, straight out of the ASI 178 ( a bit of colour added in IrfanView).
FireCapture V2.7
Gain, 169
Exp 1.7ms
fps 140
21sec 16 bit 2925 frames SER file, 3.6 Gb
FireCapture V2.7
Gain, 169
Exp 1.7ms
fps 140
- Has thanked: 20813 times
- Been thanked: 10487 times
These are excellent Ken!
- Has thanked: 9319 times
- Been thanked: 6157 times
Thanks for the positive response!
It's pleasing to see that the results of the MiniSHG are being so well received.
Next challenge will be the Mg (b2) band.....
- Jordan Konisky
- Has thanked: 386 times
- Been thanked: 270 times
Superb, Ken.
Jordan
Jordan
Jordan -
Lunt CaK B1800 Filter Module
Lunt White Light Solar Wedge
- Been thanked: 4980 times
Ken:
Superb CaK images.
Best regards and a Happy and safe new year.
Superb CaK images.
As said already before me here ken.
Absolutely amazing
Thanks vm
Absolutely amazing
Thanks vm
For comparison with Ken's fab images, SDO from the same date, shows some of the difference with SDO's AIA-304 capture.
- 3-1-2021 1518z SDO latest_2048_0304.jpg (906.35 KiB) Viewed 679 times
Once again thanks very much for the positive response!
Appreciated.
Appreciated.
- Been thanked: 4427 times
Superb CaK images there Ken
- Has thanked: 8558 times
- Been thanked: 8290 times
Fabulous prom images, Ken.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
These are beautiful prominence shots, Ken.
I’m quite surprised that you can achieve a spectral resolution of 0.08A. Do you have some spectra you could post (good image resolution) to support this determination?
Peter
Peter
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Brilliant, I quite often see prom's in CaK. Lovely captures.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Peter,
To be honest the current measured performance of the MiniSHG in Ha is around R=35475 (0.18A), this equates to x3 the dispersion of 0.063A/pixel.
Finding tight reference lines to verify best possible resolution is problematic - I should try using the Neon lamp.....(I've corrected the original post)
I'd be interested to see any CaK images taken around the same time on the 3rd Jan for comparison......
viewtopic.php?f=4&t=34393
Missed this one by Steve!
In the full res CaK image he shows the same proms......
