Sol 3-1-22 Ha & Cak
- Ibbo
- Has thanked: 2469 times
- Been thanked: 1666 times
Sol 3-1-22 Ha & Cak
A bit cooler today wooly hat and 2 layers and had to wait for the haze to clear a bit.
Ha -Lunt 60mm with Coronado SM60 for D/S ZWO 178mm cam
Cak 60mm Tak & WO 132 & Lunt 600 filter
Give the links a click as there are Cak proms which is only the second time for me.
- rigel123
- Has thanked: 8652 times
- Been thanked: 8884 times
Re: Sol 3-1-22 Ha & Cak
Nice shots!
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- Has thanked: 1640 times
- Been thanked: 878 times
- Has thanked: 9379 times
- Been thanked: 6198 times
- Has thanked: 65 times
- Been thanked: 4455 times
Excellent images Ibbo
Nice to see you caught the CaK proms too!
- Ibbo
- Has thanked: 18093 times
- Been thanked: 8935 times
These are fabulous Steve, CaK proms that's a winner
Out of curiosity I am trying out the forum support issue with astrobin, I'll see if this works
- Ibbo
- Ibbo
Found the other thread
I will try it later with todays offerings.
Thank you.
- Has thanked: 8588 times
- Been thanked: 8324 times
Very nice proms there, Steve.
Steve,
PM sent.
Need your help.
PM sent.
Need your help.
- Ibbo
I am obivously doing something wrong with the PM as I have tried a couple of times.
Both were taken on the 3 Jan with a WO 132 stopped down to about 120mm (because of a small clamshell in the lens) at native 925 mm F/L with a ZWO 178mm cam and Lunt 600 filter.
They were both captured with Firecapture, stacked with AS2 a bit of intial sharpening in Imppg then into PS for clouring and a final stretch and sharpen
both were 101 of 1000 frames
the top one above was taken at 14-03 UT 17.3 ms exposure @ 51 FPS gain 206 gamma 50 ROI 1328x1178
The second one above was at 14-02 UT exposure 17.3 ms @53 FPS gain 206 gamma 50 ROI 1384x1148
If you need any more info or even the files I should be able to drop box them to you.
Steve,
I appreciate you taking the time to answer my request.
I already know that the relative resolutions between the Lunt CaK and the MiniSHG can impact on the recording of CaK proms.
It looks like your total exposure was around 17.3ms x 100 = 1.73sec plus the sharpening etc. with a 120mm aperture to achieve your results. That could be a good benchmark.
The MiniSHG used effectively a 4.5ms frame -no stacking, no sharpening, with a 60mm aperture to give the results posted.
viewtopic.php?f=4&t=34386
- Ibbo
