An Artificial Green Rim
- Has thanked: 171 times
- Been thanked: 252 times
The image captures a green segment on the top-left limb of the sun. Green rim is an optical phenomenon visible due to the refraction of sunlight through increasing density near horizon. The refraction of green light is stronger and thus a "green" sun can be visible higher than the "red" sun creating a green rim on the upper limb. Green rims do not last long and unlike greem flashes, they are not visible to unaided eyes.
In this image, however, such a refraction is caused by the heat and dust coming out from the turbine of the airliner engine when the sun is relatively higher in the sky, creating a green rim.
Gear: Nikon D5600, Sigma 150-600c
Exif: f/11, 1/500s, ISO 100, 600mm
Date: 7th January 2021
- PSX_20220107_123150.jpg (703.51 KiB) Viewed 486 times
Last edited by SoumyadeepMukherjee on Fri Jan 07, 2022 7:02 am, edited 1 time in total.
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: An Artificial Green Rim
Lovely shot! Please keep the file size of attached images down though thanks, they can be quite slow to load for users without high speed internet.
Thanks Mark! Sorry, I forgot to resize the file. Updated with a smaller file.marktownley wrote: ↑Fri Jan 07, 2022 6:37 am Lovely shot! Please keep the file size of attached images down though thanks, they can be quite slow to load for users without high speed internet.
- Been thanked: 8907 times
Very nice, you had keen eyes to spot this, it took a while to see at full res
- Has thanked: 9327 times
- Been thanked: 6163 times
An excellent capture.
Not so much "dust" though, rather than water-vapour from the engines, as well as almost certainly a change of air-pressure (causing air turbulence) from behind the moving body of the airframe itself, would be likely.
We are always advised that flying lighter aircraft close behind (within 5-miles typically) of a large commercial/military aircraft - is known as "Wake Turbulence" to be avoided.
Thanks for the interesting image
Thank you for the excellent information Terry!EGRAY_OBSERVATORY wrote: ↑Fri Jan 07, 2022 11:47 am An excellent capture.
- Been thanked: 4981 times
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Great transit image, Soumyadeep, showing an interesting effect.
- Been thanked: 2725 times
Excellent ! Thanks for sharing.
