Solar Activity Mg (b2 and b1) 9th Jan 2022
Has thanked: 174 times
Been thanked: 619 times
Post by Merlin66 »
After four days of complete cloud and rain (28mm in one day!) finally had the opportunity through broken cloud and increasing wind to try the MiniSHG on the Mg lines.
Using the Astronomik L1 UV-IR filter, Baader 0.9ND, #56 Green and the 1mm exit slit (approx 70A)
I collected a SER video in both the b2 and b1 lines - just to see the difference (if any)
Certainly not the best images I've obtained, but under the circumstances better than nothing.
I think there is marginally more detail, faculae and penumbra showing in the b2.
What do you think?
Oh, no prominences visible...... ;(
The weather should improve next week so I'll try to image in Mg again.
Magnesium b2
Magnesium b2
Has thanked: 17813 times
Been thanked: 16953 times
Re: Solar Activity Mg (b2 and b3) 9th Jan 2022
Post by DeepSolar64 »
Hey, Ken! It's a start. Nice! Keep at it.
JP
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
great stuff Ken
best regards
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Good effort under the bad-seeing Ken.
Thanks
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Post by Stardust5858 »
Good effort Ken, are these in the magnesium wavelength?
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
I am so glad to see you back, Ella! I hope you have been OK with no COVID issues.
Stardust5858
DeepSolar64 wrote: Sun Jan 09, 2022 6:59 pm I am so glad to see you back, Ella! I hope you have been OK with no COVID issues.
Hi, no not covid although begins with c, I'll call it a little c. Nice to be imaging and observing again though.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Stardust5858 wrote: Sun Jan 09, 2022 7:22 pm
Whatever it is I hope you get to feeling better. I have certainly missed you here. So welcome back!
Re: Solar Activity Mg (b2 and b1) 9th Jan 2022
Post by Merlin66 »
Ella,
Good to see you on the forum!
Yes, the Magnesium I Triplet. b2 is the usual target (5172.8A)
Mg lines.JPG (101.68 KiB) Viewed 662 times
Has thanked: 20757 times
Been thanked: 10444 times
These are excellent Ken, thanks for sharing!
Post by Merlin66 »
Thanks for the positive feedback.
The prominent Fe lines either side of the b2 line might pose a problem with the processing software. There doesn’t seem to be a way of positively selecting a target line for subsequent processing, a feature available in Wah’s SLiM.
I’ll probably process using both INTI and SLiM to look for consistency.
KMH
Has thanked: 658 times
Been thanked: 766 times
Post by KMH »
Very nice! The SHG must be a very interesting project. How long does it take to scan an image?
Kevin
Post by Merlin66 »
Kevin,
Depending on your setup it can take between 120 sec and 9 sec.
If you just let the solar disk drift across the slit it's 120 sec. If you use the slew buttons on your mount (ie x2 or x3 sidereal) you can get down to 9sec.
The other issue is obtaining sufficient frames during the scan video.
The size of the solar disk is close to 1/100 the telescope focal length. An ED80 for example gives a solar image of 5.6mm, using an ASI 178 camera with 2.4 micron pixels this equals 2327 pixel.
To get a pretty close to circular scanned image (to minimise geometric corrections) you then need to record approx 2327 frames. This leads to a frame rate of 2327/9 = 258 fps.
(With the drift method you'd only need 2327/120 = 19.4 fps)
Hope that helps.
(Oh, it takes around 3-4 sec (!!!) to process the video into an image. The INTI software is very fast.)
Has thanked: 17925 times
Been thanked: 8894 times
Well done Ken :bow :hamster: I'm looking forward to lots of different views of the Sun from you :hamster:
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
First time I see images at the magnesium line, Ken. Interesting and thank you for posting them.
Keep em’ coming Ken!!
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Great post Ken :bow
I like the extra 'flavors' of solar energy you get to share with us ;)
MAURITS
Has thanked: 2463 times
Been thanked: 4879 times
Post by MAURITS »
Nice to see Ken.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
MapleRidge wrote: Wed Jan 12, 2022 12:04 am Great post Ken :bow
Ditto that!!!
thesmiths
Has thanked: 47 times
Been thanked: 1522 times
Post by thesmiths »
Merlin66 wrote: Mon Jan 10, 2022 8:34 pm The prominent Fe lines either side of the b2 line might pose a problem with the processing software. There doesn’t seem to be a way of positively selecting a target line for subsequent processing
Actually, using the INTI type of software, you can use the pixel shift feature to offset versus a major line in order to look at a minor line.
Post by Merlin66 »
Doug,
I agree, but that assumes the initial image is generated from the absorption line you think you have targeted.
There’s no way with INTI to be 100% sure of the line being used.
With Wah’s SLIM you have the definite option of selecting where the reference is positioned.
