January 10 2022 Observations
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Session time is from 17:30 to 18:00 UTC. The skies are clear and the seeing is about average. The temperature is a cold 38F ( 3.3C )
I can see with some effort, seven disturbances in the Ha chromosphere today. AR12924 in the SW quadrant is the easiest to see with it's two large spots. The plage forms a line bridging the spots together. A filament can be seen with some difficulty in the NW corner of the system. Just to it's NE is another plage that is not difficult to see. AR12925 is seen east of AR12924 still in the SE quadrant. It shows a single spot with plage just east of it. AR12927 is located in the far SE near the limb. It shows a single spot with plage to it's SE. The NE quadrant shows a large plage near the limb. A filament is located NW of it. SW of this system but still in the NE quadrant with effort I pick out another plage. The NW quad shows a single plage. That of AR12926.
Prominences are easily seen around the limb in double stack today. I can see almost all of them that the GONG images show. The NE is particularly active with them. The NW has one reminiscent of the " Golden Arches "!!
The mottles are easily seen across the disc.
I can see five areas of activity on the WL photosphere today. AR12924 in the SW quadrant shows two nice spots with umbra/penumbra form. The NW spot shows two small spots at it's NE side. One of these is embedded within the larger spot's penumbra! AR12925 to the east of AR12924 shows a umbra/penumbra structured spot with two tiny spots/pores very close to it's SE side. AR12927 in the far SE shows a umbra/penumbra spot amid an easily seen large patch of faculae. The NE quad shows a large patch of faculae without spot or pore. AR12926 in the NW quadrant shows itself as two small spots.
The fine granulation is seen easily today.
The session music for today is Resurrexit by Taize.
Carpe Diem!
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: January 10 2022 Observations
Post by EGRAY_OBSERVATORY »
Thank you James and you've answered the query as where AR2926 is/was/is ..
Thanks vm for the report
Has thanked: 20757 times
Been thanked: 10444 times
Half and hour well spent James. Just grey, damp and drizzle here for me today, but I was at work so I guess it doesn't really matter! Bring on better weather and a higher sun!
Terry,
Yep, I solved the mystery of the disappearing AR12926. :-D !
Good luck, Mark! Yes, I wish you clear skies and a higher sun!
Has thanked: 17925 times
Been thanked: 8894 times
Thanks James, you keep us well informed when we sit under damp skies :)
:hamster:
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Thank you, James, for the report. Cold here, in the mid teens this morning.
EGRAY_OBSERVATORY
Thanks again James and today SDO shows almost exactly the same disk layout with that AR2926...
Thanks and welcomes everyone. I will be setting up for today’s session shortly.
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Thanks for the report, James, you keep us all informed. The sun in the last days is very beautiful. We have had low heavy clouds for a long time, and I'm already starting to forget what it looks like :)
Ivan
Ivan,
I try to help you see.
Ivan
Post by Ivan »
Thanks James. You are doing great.
Ivan
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Good report for the days solar activity James!
I haven't been out the past few days...lots of snow yesterday and woke to -32.5C this morning :shock: If it hadn't clouded up I might have tried to do some solar work, but I had to work and lost the window.
Wow, Brian. That's arctic cold! You are a tough one to observe in that, even with an observatory.
James I can't argue...it was cold! I didn't get out though due to work and clouds.
Just an example of how much the weather will change here...-32.5 Tuesday morning at sunrise and -1.5 this morning. Quite the swing in temps :?
That is quite a bit of change!
Thanks everyone!!
