Transit
- Has thanked: 9387 times
- Been thanked: 6199 times
Transit
Hello all: this is from back in September, I only had time now to process it. Most likely from nearby Sikorsky airport.
Fast
https://youtu.be/H1WfgRByV_k
Slow
https://youtu.be/2AJPjgb2AC8
Fast
Slow
- Has thanked: 17960 times
- Been thanked: 17106 times
Re: Transit
It looks like a single engine turboprop aircraft. Probably someone's corporate plane.
Nice video!
Nice video!
- Has thanked: 20957 times
- Been thanked: 10589 times
Re: Transit
That's a nice capture Franco! Transits are always a bonus...
- arnedanielsen
- Has thanked: 6353 times
- Been thanked: 7411 times
- rsfoto
- Has thanked: 9823 times
- Been thanked: 5826 times
Re: Transit
Hi Franco,
Excellent catch. If you knoe the exact time of the pass you can check at
https://www.flightradar24.com/24.12,-104.44/7
what type of plane it was near your place ... Those are my coordinates ...
Re: Transit
Here it is at my place rainer https://www.flightradar24.com/airport/bhx
- Been thanked: 4900 times
Re: Transit
Very sharp and excellent capture Franco.
This is a Pilatus PC-12 private/corporate turbo-prop executive type.
May only show on FlightRadar if its' Squawk box is "sqawking ADS mode "C" or
better and not necessarily "7000" - unless in controlled airspace...
As undercarriage retracted and not knowing the height/altitude -
it may not be in that "controlled airspace."
https://en.wikipedia.org/wiki/Pilatus_PC-12 explains.
A beautiful design and manufactured aircraft - one of which I had a look
inside and out, some years back at an Air Fair...
Being a Swiss design/manufacture is, as expected to be a very fine product
- even at the price too...
They can be seen over S.E. England - often and on my radar and web-links.
Re: Transit
Thank you Terry for your comments and for sharing your extensive aviation knowledge !
Re: Transit
No probs Franco and at least the animation was clearly visible to me this afternoon
and needed that answer. In fact much-easier than seeing what I've typed in this small print..
Best Wishes and keep filming so very-well the transits as well as the Sun of course.
- Has thanked: 8588 times
- Been thanked: 8324 times
Re: Transit
Excellent transit, Franco.
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
