Lugged the 127mm F7.5 Triplet Meade out.
Tried the Quarks on it and OK.
Put the PST Mod2 on. F10 so 90mm. Collimator, PST Etalon, Gap, Re-Focusser, KG3-UV/IR, Red 25A, Circ-Polariser, gap, Baader 7nm, Omega 1.5A tilted, bino-viewers 16x
I can see the prominences and lots of surface details so between the Prom and Chromo Quarks.
Rare black background so must be clear.
Just noticed these Rivers of Fire.
https://gong2.nso.edu/HA/hag/202201/202 ... 3530Ch.jpg
Cheers. Andrew.
Rivers of fire
- Has thanked: 3317 times
- Been thanked: 1907 times
- Has thanked: 20819 times
- Been thanked: 10489 times
Re: Rivers of fire
You've had a good day under the sun Andrew
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: Rivers of fire
I noticed these as well but I could not see them so clearly because of rough seeing. Good seeing and the SMII90 would have rendered me an excellent view :-(
