Prominences 18/01/2022 90mm Chromo
AndiesHandyHandies
Has thanked: 3304 times
Been thanked: 1902 times
Post by AndiesHandyHandies »
90mm Triplet F6.7, 2" Thermal Dump/Stop, 2" Baader UV-IR, T2 Thermal Dump/Stop, 4.2x, Quark Chrom, Celestron 40mm
2.00 Light cloud breeze
7.00 Teddy bear at top fuzzy hedge below with arch over to TB.
8.30 Stub prom extending down.
11.00 Little stub prom
12.00 Little pyramid. Bright small jet up to right
1.00 Glimpsed separated fuzzy area
1.30 Little prom, over the bottom 2 spots of 4
6.00 Stubby prom with short 'arms'. Little stubby jet extending up
Lots of surface details similar to yesterday. Wait for the images.
Cheers. Andrew.
Has thanked: 20732 times
Been thanked: 10427 times
Re: Prominences 18/01/2022 90mm Chromo
Thanks Andrew!
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
Andrew,
You certainly did better on proms than I did. I did get an M-class flare though. I'll post the report asap. I gotta get back to shoveling snow.
Has thanked: 17888 times
Been thanked: 8887 times
Fabulous Andrew, thanks :hamster: I was staring out the window yesterday at the Sun but was too busy at work :(
Alexandra, you need a pair of Lunt 8x32 SUNoculars for a quick view!!
