17th Jan 2022 session
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all,
Just got around to process the 17th January images in WL, CaK and HA. Bit rushed today so probably could do better. It was hard to tune the HA scope because of clouds.
- 20220117-131031UTellabryant-CaK-FD-invert.jpg (1014.5 KiB) Viewed 359 times
- 20220117-131031UTellabryant-CaK-FD-invert-col.jpg (1021.21 KiB) Viewed 359 times
- 20220117-131031UTellabryant-CaK-FD.jpg (769.04 KiB) Viewed 359 times
- 20220117-131031UTellabryant-CaK-FD-col.jpg (1.04 MiB) Viewed 359 times
- 20220117-131431UTellabryant-CaK-Prom-South East Quadrant.jpg (100.88 KiB) Viewed 359 times
- 20220117-131431UTellabryant-CaK-Prom-South East Quadrant-col.jpg (176.6 KiB) Viewed 359 times
- 20220117-131539UTellabryant-CaK-Prom-North East Quadrant.jpg (52.4 KiB) Viewed 359 times
- 20220117-131539UTellabryant-CaK-Prom-North East Quadrant-col.jpg (96.05 KiB) Viewed 359 times
- 20220117-133933UTellabryant-WL-FD.jpg (1.12 MiB) Viewed 359 times
- 20220117-133933UTellabryant-WL-FD-col.jpg (1.05 MiB) Viewed 359 times
- 20220117-143153UTellabryant-HA-FD.jpg (969.77 KiB) Viewed 359 times
- 20220117-14332UTellabryant-HA-AR-C-flare-col.jpg (764.49 KiB) Viewed 359 times
- 20220117-14332UTellabryant-HA-AR-C-flare.jpg (663.31 KiB) Viewed 359 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Re: 17th Jan 2022 session
Nice session, Nigella.
Proms in CaK and C-flare are hard to catch, you did it. Your FD's are perfect, I especially like Ha.
Ivan
Ivan
- Stardust5858
Thanks very much Ivan, much appreciated. I do love seeing the proms in CaK I must admit. I did another session today 19th and the proms in CaK were really nice. Hopefully post those tomorrow.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 17855 times
- Been thanked: 17003 times
Wonderful work Nigella! You did great on the CaK prominences and catching a flare in AR12930! In fact you got all three lights well.
- Has thanked: 20822 times
- Been thanked: 10498 times
A nice set of images Ella!
- nicspenceryork
- Has thanked: 6087 times
- Been thanked: 1321 times
- Has thanked: 8559 times
- Been thanked: 8297 times
Wonderful flare capture and great disk images, Nigella.
- Stardust5858
Thanks everyone for your positive replies, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 8907 times
Well done in catching the CaK proms and the flare a fabulous harvest
- Has thanked: 9327 times
- Been thanked: 6163 times
- Stardust5858
Thanks Alexandra and Franco, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
