Clear. Breeze.
90mm 6.7 Energy dump Baader UV/IR Energy dump Baader T2 Prism
3x Revelation at 4x, Prom, 25mm Clave'
12.40pm
6.00 Faint fuzzy prom up, gap and then curved over to right.
8.45 Small jet.
12.00 Hedge prom taller on right then a fuzzy arch.
12.55 A little pyramid with a small hedge stub below
3.00 A triangle top at bottom then a thin spike
4.2x Quark and Chromo 40mm Celestron
12.55pm
Proms
6.00 Nothing visible
12.00 Hedge prom taller on right then a fuzzy arch. Under right of tall part of hedge a triangle filament down, tails edge and centre.
Chromosphere
1.00 G4 Spot below with 3 white lines one off the spot and 2 below.
7.30 G 10.30 A dark spot with white areas around.
6.30 G9.30 A dark filament bracket facing down with two low triangle filaments in a line off the bottom.
Addendum
2.00pm
Proms
6.00 Small jet leaning right
7.30 above dark spot 3 small stub proms
12.00 Hedge prom taller on right then a fuzzy arch, now in two parts.
1.30 2 small proms
2.30 Tiny, small and tiny prom.
3.00 Thin spike
3.30 Small pyramid leaning up
Cheers. Andrew.
Prom and Chromo 21/12/2022
- Has thanked: 3295 times
- Been thanked: 1887 times
- Been thanked: 4904 times
Re: Prom and Chromo 21/12/2022
Andrew, a very nice and interesting session report.
- Been thanked: 8794 times
- Been thanked: 10248 times
Thanks Andrew. You've been getting some nice viewing in recently!
- Been thanked: 4340 times
Good review of your observations Andrew!!!
