Walkthrough the CaK wavelength violet to red
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
I've prepared a GIF which walks through the CaK wavelength at a resolution of 0.18A.
Starts way out in the K1violet wing (1A), creeps in until the K2v region, just outside the core (0.2 offset) then the core CWL and then the same points moving outwards into the red wing.
I'm looking at ways and means of combining the images to better represent the views obtained with the Lunt filters (and others)
Enjoy!
Has thanked: 17807 times
Been thanked: 16940 times
Re: Walkthrough the CaK wavelength violet to red
Post by DeepSolar64 »
Very nice work Ken! You are at the forefront of CaK/SHG imaging. I hope to see more of your magnesium work as well.
Thanks
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Interesting ken and keep up the good work
Post by Merlin66 »
Thanks for the feedback!
I will process a similar series but showing the Proms in action and where the brightest proms can be found.
Has thanked: 20732 times
Been thanked: 10427 times
This is brilliant Ken, you're giving me lots to think about for optimising my filter based CaK setup. These reference images are gold.
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Very nice and interesting, Ken.
Has thanked: 17888 times
Been thanked: 8887 times
Brilliant Ken :bow :bow :hamster: is this done with the miniSHG?
eroel
Been thanked: 4957 times
Post by eroel »
Ken:
Very good walkthrough different wavelengths.
Best regards and thanks.
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Well done Ken !
On my side, I am considering a 1.5A Ca K filter from Alluxa. Still, the spectral resolution would be much lower compared to the SHG.
Post by Merlin66 »
Alexandra,
All the images were obtained from one MiniSHG 18 sec 16 bit SER video. Matt and I have been playing with the INTI software to make it more robust in the selection of target lines. This allows more precise wavelength selection across the target line.
I'm also preparing a similar animation for the Proms.
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Excellent, Ken. Very interesting to see the changes across the series of images.
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Very nice, Ken.
Might I recommend more spectral “slices” for a smoother animation?
Here’s an example I posted in 2018.
viewtopic.php?f=8&t=25028
Peter
p_zetner
Post by p_zetner »
Merlin66 wrote: Thu Jan 27, 2022 7:29 pm I'm looking at ways and means of combining the images to better represent the views obtained with the Lunt filters (and others)
For a discussion of simulating filter bandpass effects with SHG images you might want to check my thread in our very own SolarChat Reference Library entitled “‪Surface contrast in CaK for various filter bandpasses”.
viewtopic.php?p=225389#p225389
To give a reasonable simulation of Ca K filter performance, I used a weighted average of SHG frames across a spectral sequence, weighted in such a way to mimic a Gaussian filter profile. Further details are discussed in the thread.
The results are also shown in Figure 7.23 of Christian’s “Solar Astronomy” book.
Peter
Post by Merlin66 »
Peter,
You are correct. I could have taken many more images....next time.
I just wanted to show the relative changes between the K3, K2 and K1 regions of the Ca II K line.
Sorry, I had overlooked your earlier work.
