One and only of the day 14th May 2022
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Opened up the observatory this morning under cloudless blue sky,aimed my air spaced Helios 150 f/8 achromat at the Sun just after 10:30 UT and after having focused I got the first 2000 frame SER with the Lunt CaK B12 module and QHY5III 178M at 10:34 UT and then twenty minutes in the limb of the Sun was boiling,focusing was nigh on impossible,but I persevered thinking the seeing would settle..What do I know?? So this is the only image of the day showing yet another transformation in the sunspot group AR 3007 as it creeps across the face of the Sun. Stacked in Autostakkert and sharpened using ImPPG and finished in Photoshop CS2.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
SW Evostar 72ED for full disk imaging
Sol'Ex SHG
80mm f/7 achromat used with pressure tune module off the Lunt with Lunt 100mm ERF
Bresser 90 f/10 achromat used for CaK & white light imaging & PST mod with Lunt 100mm ERF
Coronado SM40 (pre Meade) and BF10 filter set + SMII 60 richview DS etalon
Skywatcher EQ6 Pro and Ioptron CEM60
Then there is all the night kit which is far too long a list to write up here!
More images on view on my Flickr page...https://www.flickr.com/photos/alun_h/
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 17581 times
- Been thanked: 16696 times
Re: One and only of the day 14th May 2022
WoW, Alun. That's an impressive view of AR13007 in the light of Calcium II K.
Is your Helios 150 achromat of Chinese manufacture?
- Been thanked: 4904 times
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Very nice result, Alun.
Seeing was a mess here yesterday as well.
- Has thanked: 2412 times
- Been thanked: 4787 times
- Alun_H
Thank you all for your kind comments
James,yes it is Chinese made and is the same scope as the Celestron C6-R with the collimatable objective cell.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 9145 times
- Been thanked: 6025 times
Great shot Alun. Are you using any Barlow or telecentric to get this close ?
- Alun_H
Thank you Terry
Thank you Franco,no Barlow nor telecentric used,just prime focus of the scope which has a focal length of 1200mm and using ROI on the camera in
Firecapture.
Alun
Firecapture.
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
