Grasshopper 3 test
Has thanked: 1081 times
Been thanked: 368 times
Grasshopper 3 test
Post by Montana » Mon Aug 26, 2013 6:32 pm
Just a couple of photos, the poor computer has been churning all afternoon, the Grasshopper really takes ages to process. The DMK41 was taken in good morning seeing, the Grasshopper (last on the list for testing) was taken around midday and wobbly seeing. I can really only see a major difference in real estate at the moment, but I can certainly say it is much more sensitive in Halpha than the DMK41, it is quicker and I only saved 600 frames rather than 1000. You blink and it has done 600 frames!
DMK41 (DSF-100 / 1.6x Barlow)
2013-08-26 10-05-32 DMK41 by Alexandra's Astronomy, on Flickr
Grasshopper 3 (DSF-100 / 1.6x Barlow)
260813_112424 PGR Grasshopper 3 by Alexandra's Astronomy, on Flickr
and the Grasshopper made pretty
260813_112424 f colour by Alexandra's Astronomy, on Flickr
However I couldn't use 16 bit with the Grasshopper as I got the kiss of death when I pressed that button ;)
Michel, the war begins (well, I don't stand much chance against you really :lol: )
Derek Klepp
Been thanked: 93 times
Re: Grasshopper 3 test
Post by Derek Klepp » Mon Aug 26, 2013 6:46 pm
What a marvellous area to test on.That pics put me an a good frame of mind for the day.
RobBower
Post by RobBower » Mon Aug 26, 2013 6:47 pm
:bow: :bow: :bow: outstanding! :hamster: You must be thrilled!
If I can still buy a new one.....Im not afraid to rip this 1 apart!
Island Grove Observatory on the south shores of Lake Simcoe
Ls60pt/Ls50DS, Lunt 2" HW, PGR Flea3-DMK51
Meade 127mmED Triplet NEQ6 Pro
127mm PST mod. 950mm Meade Series 5000 Triplet
http://www.flickr.com/photos/98998648@N07/
astroshot
Post by astroshot » Mon Aug 26, 2013 6:53 pm
Alexandra,
As you say, the main difference visually seems to be in frame size. Both give great detail.
Interesting you say that the Grasshopper is much more sensitive than the DMK41. In theory, for the same number of frames, I would expect the Grasshopper to reveal slightly sharper detail as it would freeze the seeing better due to the shorter exposure length.
Then again, there was a *lengthy* discussion on one of the Facebook groups about this issue recently. I forget what the conclusion was TBH...
Does the Grasshopper need USB3 or SSD or anything like that?
How did you find the software to use?
Michael OConnell
I87 Astroshot Observatory
Coronado Solarmax 90
Daystar 0.6A T-Scanner
colmic
Post by colmic » Mon Aug 26, 2013 7:07 pm
AHHHHHHHHHHH!!!
So the day has arrived!
This is a very good first attempt, go to correct this BSOD with 16bits option and you'll really see the difference.
VS a DMK41, Grasshopper3 has:
- more sensitive sensor, far more
- more dynamic range, far far more
- less noise, far far far less
- bigger sensor, far more
- more fps, 2x more
The unique point they are equal is in the pixel size (4.65 vs 4.54), the resolution is identical
So YES, YOU WILL see the difference :)
Michel Collart
http://astrosurf.com/colmic
Takahashi TSA120 on Vixen Sphinx NexSXD
Coronado SM90 Double stack (type I) + BF15
Intes Hershel prism
PGR Grasshopper3 ICX674 camera
solardave
Been thanked: 8 times
Post by solardave » Mon Aug 26, 2013 7:09 pm
fantastic alexandra :thumbsup: :bow:
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
p_zetner
Has thanked: 3 times
Been thanked: 71 times
Post by p_zetner » Mon Aug 26, 2013 7:16 pm
Those are superb, Alexandra!
Peter.
gabrieli
Been thanked: 95 times
Post by gabrieli » Mon Aug 26, 2013 7:43 pm
Like silk.
Post by Montana » Mon Aug 26, 2013 8:09 pm
Thank you :)
PS the hubby has attempted to download the driver thing, will see if I get the kiss of death again with the 16 bit tick :)
sullij1
Post by sullij1 » Tue Aug 27, 2013 12:42 am
Good luck with the Grasshopper. :bow:
Look Up!
solar
Post by solar » Tue Aug 27, 2013 5:28 am
Great you got that thing working Alexandra. Hope you solve the 16Bit thing.
Me I can't even down load Fire Capture. Sorry I even bought the Thing. Long live DMK.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 12", C8 CG5, Megrez80, SBIG2000 MXC,
PGR 2.8 Grasshopper PGR Flea3, DMK21 ASI 120mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
pstew
Post by pstew » Tue Aug 27, 2013 6:13 am
Awesome :bow: :bow:
Paul
Timaru, New Zealand
LS152Tha/B34/DSII, LS80THa/B18/DSII, LS60Tha/B12, Grasshopper3(ICX687), Chameleon 3(IMX264)
Has thanked: 1220 times
Been thanked: 496 times
Post by marktownley » Tue Aug 27, 2013 7:59 am
Very good images Alexandra, that camera is a keeper 8)
DJD
Post by DJD » Tue Aug 27, 2013 8:44 am
Been following your trials and tribulations with some interest.
The results speak for themselves. Well worth the effort.
Brilliant :bow:
David
solar
Post by solar » Tue Aug 27, 2013 9:03 am
Alexandra I know there is a thread here somewhere about your troubles downloading Fire Capture and passwords but I can't find it. I'm having the same trouble. Help :kiss:
Post by Montana » Tue Aug 27, 2013 9:25 am
When you download Firecapture, the user is firecapture (little f) and no password. It then should download (download 2.2 first)
All the instructions from Colmic (michel) are here + my little fixes at the end of the thread http://solarchat.solarastronomy.org/ind ... sshopper-3
also be sure to download this Intel driver https://downloadcenter.intel.com/Detail ... ldID=21129
Many thanks everyone, lots to process and lots to test :)
Post by marktownley » Tue Aug 27, 2013 10:09 am
which chip is it in your grasshopper alexandra?
colmic
Post by colmic » Tue Aug 27, 2013 10:52 am
Same as mine Mark, ICX674 2.8Mpixels. Very, very good sensor for solar imaging, if not the best actually...
Michel Collart
Intes Hershel prism
gabrieli
Post by gabrieli » Tue Aug 27, 2013 12:00 pm
Hi Alexandra
Since I don't have a double stack yet and some unusual processing on double stack images gives interesting results,
I took the liberty(if you would prefer that I remove this, just let me know) of using one of your images and applied the Shadows/Highlights technique outlined in Michel's (colmic's) tutorial (values: 60/10/10,20/50/800) to see if extra detail could be brought out in the off-limb features.
Here's the result:
Your original is on the left
I'm still struggling with my own attempts but your images seem to lend themselves to this processing effectively even using
the 8 bit images off the screen.
Post by Montana » Tue Aug 27, 2013 2:11 pm
Wow! that's very good! I've never had much luck with shadows and highlights myself as I just get in an artificial mess, this looks very natural though and I'm interested :)
etatsolarchat
Post by etatsolarchat » Mon Sep 30, 2013 5:21 pm
Those of you that have a ICX674 PGR... do you get a dark band on the top and bottom of the frame like this? Ignore the corners, its the top and bottom band that annoys me and don't know where it's coming from... If I swap out the camera for a same size sensor the ICX625, the bands are totally gone, so it seems to be the camera body or sensor? I have a grasshopper express but I believe I saw others with this issue with grasshopper 3 version also.
gabrieli
Post by gabrieli » Mon Sep 30, 2013 6:15 pm
Hi Eric
I know that "misery loves company" is no consolation but, yes, your situation is identical to my situation wth dark bands just inside the top and bottom of the frame. Your question is one I asked after I started using my 2/3" G3 many months ago. I also get a single dark band across the top of the frame in my Chameleon.
I don't know what causes it, whether it's an interference effect, and I don't recall whether it happens in white light.
If it doesn't happen in white light, it may be an interference effect due to the narrow wavelength used at the very narrow gap
between the sensor and the protective glass just above it where it's supported at the edges.
Most of the time, I don't need the entire frame, and crop the frame or use a slightly smaller ROI. However minor it has turned out to be, I would like to use all the real estate I paid for.
There is a question I'd like to ask you and other Grasshopper 3 users. In Firecapture, does your Liveview screen "flash" briefly
when you adjust the shutter speed? This doesn't happen in Flycature, only in Firecapture.
gabrieli
Post by gabrieli » Mon Sep 30, 2013 6:20 pm
Have you tried recording in 16 bits using the PGR software? Use "streaming" mode instead of buffering when you choose
your format.
Post by Montana » Mon Sep 30, 2013 6:23 pm
I get those lines too, you have to cut them off :( but only in Hydrogen alpha as it is not there in WL :?
I have been using the 16 bit, although I forgot to tick the button yesterday :blush: I've not seen a buffering or streaming button yet?
Post by swisswalter » Mon Sep 30, 2013 9:23 pm
Hi Alexandra
congratulations, that seems to work
Hi Eric
I have the same problem with my Basler Ace 640-100 gm
