Solar processing in Pixinsight
Moderator: marktownley
- Has thanked: 1640 times
- Been thanked: 878 times
My normal processing is a combination of ImPPG and PS but decided to work in PI recently. I think my preference is sharpening in ImPPG and then touch up in PI. There are some interesting tools in PI.
Import image then crop out borders
Run DBE only selecting background
Sharpen. You can use restoration filter (easier) OR deconvolution. both you need to guess PSF size and then unsharp mask. you can also sharpen with wavelets
Comparison between RF and Decon
Unsharp Mask after deconvolution
Boost contrast with LHE. I will use large and a small kernel size (512 and 16) with small amount
Then blend in with pre LHE to soften it a little.
Here are a couple of pixelmath options (I tend to adjust the amounts blended). or I used (a * .2) + (b *8)
Then touch up with curves and HST
12-12-21 Ha by Diamond, Alan, on Flickr
Re: Processing in Pixinsight
Here is how I generate a pseudoflat
duplicate image and remove structures DBE (just generate background model without correction) Need to resample the DBE background model Use pixelmath resampled background model from original (adjust the equation for desired effect) Here are a couple of masks that can be used to focus on pertain areas of the image. I blur with convolution to generate a softer mask
- Rob63
- Has thanked: 599 times
- Been thanked: 619 times
Excellent tutorial, I have been playing with Pi for my solar images but have never really settled on a workflow so this is a big help.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
You can extract wavelets to find where the noise and structure reside then use wavelets to sharpen and do noise reduction (on original not the extracted layers). Extracted layer 0 corresponds with layer 1 in ATVW and layer 1 corresponds to layer 2 in ATVW, etc
- Has thanked: 9710 times
- Been thanked: 5769 times
Hi and WOW
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Thanks Rob,
Still only learning the basics. Too advanced for me.
Magnus.
Magnus.
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
I previously only processed in PI then transitioned to PS about 3 years ago. I wanted to revisit the older techniques and add in a few more. I still like sharpening and curves (to bump up proms) in ImPPG but can use PI for techniques when warranted.
- Radon86
Re: Solar processing in Pixinsight
Yes, I have seen Pixinsight processing on Youtube e.g. Chuck's astrophotography. Seems really easy when you know how.
I am sure it is not impossible, just that I thought Pixinsight is more for deep sky imaging processing e.g. Eagle Nebula, Tarantula nebula, Andromeda M31 etc
Magnus
Magnus
It is definitely designed for deep sky but can be adapted for lunary, solar.Boso36 wrote: ↑Sat Dec 25, 2021 11:12 am Yes, I have seen Pixinsight processing on Youtube e.g. Chuck's astrophotography. Seems really easy when you know how.
Magnus
- Radon86
Fascinating. I was wondering if you could envisage a way of automating solar image processing in Pixinsight, like AI to retouch a face in seconds ? It would take 4-6 hours for a human to do this.
Just wondering.
Magnus
Just wondering.
Magnus
Yes, you use processcontainer and drag to the image or image container for several images
For example
I processed a Cak image
Open history explorer in the side bar Open processcontainer and drag from history explorer to processcontainer
Then drag the new instance ( triangle ) in the left lower corner to the workspace and save process (process-> process icons-> save process icons) and it will be saved for future images. You can open and drag to an image and it will process it quickly
It works great for animations combined with image container
I process a single image then drag the history to processcontainer and then load all the other images in imagecontainer (you have to drag the "new instance" (triangle) in imagecontainer to the workspace) then apply processcontainer and it will apply to every image in imagecontainer.
For example
- Screen Shot 2021-12-25 at 6.13.47 AM.png (294.12 KiB) Viewed 5911 times
- Radon86
Thanks Torsinadoc,
Very powerful.
This should be referenced in Software Processing section of this forum, I wish I could bookmark this page for future reference.
Thank you so much.
Magnus
Very powerful.
Thank you so much.
Magnus
You can also drag processes that you normally use in your workflow to processcontainer and save to workspace then open an image and processcontainer and double click each process and adjust to your liking.
- Has thanked: 17970 times
- Been thanked: 8905 times
Thanks Alan, once all the additions have calmed down I will put a copy in the library so everyone can find it more easily
If you don't want to use pixel math, you can use "blend" script. This functions like layers in PS
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
Great write up! I've found that for most instances, I prefer pixensight and deconvolution for my solar sharpening, especially when using the combined wavelet noise reduction, and then doing multiple iterations at progressively finer levels of detail. It seems to let me get a bit finer detail but with much less noise/artifacting than I'm able to get via imppg.
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- MoonPrince
- Has thanked: 7 times
- Been thanked: 228 times
That's a great tutorial, I will try your processing method later
Thanks for sharing!
Thanks for sharing!
Telescope: ES127CF APO F7.5, LXY80APO F6
Mount: SW AZEQ6, iOption GEM45.
Camera: Player One Apollo-M MAX(IMX432), Apollo-M(IMX174), Apollo-M MINI(IMX429)
Accessories: Daystar Quark Chromosphere, Herschel prism, TV5X, TV2.5X
- Has thanked: 8543 times
- Been thanked: 8280 times
Thanks for this. There’s some really great information here. I use a combination of ImPPG and PixInsight, but haven’t really explored PI deeply enough to understand all possible processing options, so information such as this is extremely helpful, especially applying FD false flats. I also haven’t explored using process container and start from fresh each session, which can be tedious when setting up various parameters.
This is yet another excellent example of the benefit to all of this generous knowledge sharing forum.
Thank you.
Thank you.
- Has thanked: 20783 times
- Been thanked: 10462 times
Excellent resource, thanks!
Any further thoughts anyone?
Here is an excellent reference for PS blending using pixelmath
http://trappedphotons.com/files/Present ... ations.pdf
And I have no further thoughts
