3D printing and SHG
3D printing and SHG
Quick question for SHG makers here: have you ever considered using a 3D printer for making a SHG? 3D printing would allow easy and rapid design of small parts such as holders for grating, slit or lenses. The material is also pretty strong and very light.
For exemple I am currently making a small spectrograph for imaging absorption spectra of gemstones. The main body of the spectrograph and grating holder will be 3D printed. Colimator and camera lenses will be attached to the main body using custom-made flange screwed to the main body. This can easily be converted to an SHG by adding a telescope.
Modelled main body, final print will be 10cm in lenght and take 4 hours to be printed. You can see the two openings the lenses will be fixed on. Printed grating holder. It needs just a bit of sandpaper and the grating should fit tightly inside.
- Has thanked: 20778 times
- Been thanked: 10456 times
Re: 3D printing and SHG
Good design work!
- Has thanked: 57 times
- Been thanked: 1202 times
real cool
I gotta look into this 3D printing jazz
seems that it can solve a lot of issues
must find out what it cost and how much room it takes
Thanks Mark
Highfnum,
Most cities and universities now have a "maker space" where 3D printing machines can be used for very cheap or even for free sometime. Generally you have to first take a short course to learn the basics, then you can come anytime and print anything you want by yourself. That is what I am doing right now. There is also the more expensive route to buy a dedicated 3D printing machine, but they come in all size and quality so you would have to do a lot of research.
Highfnum,
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
A great idea, well worth considering. Constructing an SHG out of metal parts can lead to a heavy build and care must be taken to ensure that the "engineering " leads to a solid, stable and adjustable assembly. 3D printing with plastic would certainly help with the weight issue.
Just finished printing the body of the specrograph. The grating holder will stick out from the small hole on the top for rotation.
Way cool!
I agree!
Paul Gerlach has a LOWSPEC 3D design which seems to be popular......
If you’re considering a SHG, then a longer focal length spectrograph, to suit the telescope being used may be more appropriate.
Certainly seems the way of the future.....
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
And here's a successful build of the LOWSPEC spectroscope (in Polish): https://astropolis.pl/topic/68522-wydru ... ektroskop/
First light: https://astropolis.pl/topic/69238-widmo ... o%C5%9Bci/
Very nice results!
Maybe you could suggest on their forum to look at BASS Project for the processing and measurement of the spectral images..
https://groups.io/g/BassSpectro
The program is available here:
https://groups.io/g/BassSpectro/files
Ken
Ken
Hello all,
Here is an update on my 3D printed spectroscope. It works very well! I just had to cover it with alluminium tape to prevent light leaking through the plastic body.
Raw spectrum of a fluorescent lamp: you can see I have a "smile" problem, I don't really know how to avoid it. Spectrum processed in photoshop: I loose a little bit of spectral resolution in the process but it is much nicer. The spectroscope:
Tara,
So far so good!
I would recommend you look at BASS project to process and calibrate your spectral image.
It will allow you to correct for tilt/ smile/ slant, measure FWHM and the R value of your instrument.
So far so good!
Thanks Ken,
I downloaded BASS. However I am working on a Mac, and the software cannot seem to run on my windows emulator. I will need to find a solution to have a windows partition on my mac to make it run.
Tara
Tara
- p_zetner
Beautiful spectrum. As Ken suggests, a determination of fwhm and R value of your device would be interesting to find out using BASS or similar software.
As far as “smile” is concerned, slower optics (higher f#) will help.
Impressive results!
- Has thanked: 17970 times
- Been thanked: 8904 times
