Orionids by radio detection-UPDATED
- Has thanked: 8559 times
- Been thanked: 8297 times
Radio detected Orionids (Halley's comet debris) which peaked 20/21st October, though detections began sooner (looks like around 14th).
Not as impressive as the Perseids, but detectable nevertheless.
Thanks for looking.
Thanks for looking.
- rsfoto
- Has thanked: 9733 times
- Been thanked: 5777 times
Re: Orionids by radio detection
Hi Stu,
Very good. I got 20 times the maximum impacts you have recorded. I am still working out what is going on. ¿?
Hi Rainer,
It depends how the count rates are calculated, as the apparent hourly rate can vary significantly depending on the time period over which the counts are collected. Can you plot the growth of the cumulative count over a 24 hour period, or send me your data for October 20th and then I can do a direct comparison with mine?
Cheers
Cheers
- Been thanked: 8907 times
That's great Stuart, however these peaks are only marginal compared to baseline rates which surprises me, however, that could be normal and this is why folks get disappointed when nothing happens when they watch the heavens for 30 minutes
- rsfoto
Hi Stu,Carbon60 wrote: ↑Thu Oct 22, 2020 9:03 pm Hi Rainer,
Cheers
You can download it from here
https://www.rmob.org/livedata/live_data ... 20rmob.TXT
Rainer
- Has thanked: 99 times
- Been thanked: 121 times
Dear all,
My Orionid results over the past few days for comparison.
Moxon ariel working GRAVES with SDR# displaying "pings" on the computer monitor. The display is automatically screengrabbed while the detection system is running and counts are done manually and turned into the graphical displays for interpretation.
Regards to all,
Les
Regards to all,
Les
8" SkyWatcher reflector on HEQ6. 10" Meade S/C & 16" Meade reflector awaiting obsy "planning permission"!
Coronado PST & Lunt Herschel wedge for 120mm SkyWatcher refractor on EQ4.
Graves meteor detection system.
Canon 70d & ZWO ASI120mc for imaging.
Photoshop skills questionable.
Nice one, Les.
Re: Orionids by radio detection-UPDATED
Some updated radio detection data.
Looks like another bit of a spike in the Orionid shower on the 24th, maybe....
Thanks for looking.
Thanks for looking.
- rsfoto
Hi Stu,
My former statistics lack of accuracy. Changed my setup. Took out the Low Noise Wideband amplifier and installed a home made Helical Bandpass filter for 174.31 MHz.
My friends set up and mine are quite sunchronized in catdching metoers but still differences.
He is 70 meters lower in height then I am.
Below an image of the Helical Bandpass filter I built for gettting rid pf the RFI [Radio Frequency Interference] downtown. Makes the noise level much flatter and the SNR comes out better. All this thanks to some HAM Radio amateurs in the Ham-Antennas group.io.
My friend did no get more then maybe 5 echoes a day and now he gets nice echoes during24 hours. Similar to me.
His statistics, before and after
Below the Helical Bandpass filter in open and closed conditions while I was tuning it with a Nano VNA [Virtual Network Analyzer]
Excellent, Rainer. That’s an impressive build. It will be interesting to see how the data stack up over the next couple of months with the Leonids and Geminids coming up.
I’ve noticed that nearly everyone gets different results in terms of numbers and timings of peak showers. So much depends on the specifics of each location and setup, it seems.
Your setup has come along in leaps and bounds, as we say, so really nice work, Rainer.
- rsfoto
Hi Stu,Carbon60 wrote: ↑Tue Oct 27, 2020 6:48 pm Excellent, Rainer. That’s an impressive build. It will be interesting to see how the data stack up over the next couple of months with the Leonids and Geminids coming up.
Thanks. It is already very interesting as my friend Downtown has the same set up as I have and the capture is already different and we are only 4.5 km apart.
Same Antennas, same Bandpass filter both built by me, Same RTL-SDR. Same adjustments in SDR# and Spectrum Lab ...
There is a so called eventlogYYYMMDD.txt file with some data. We will compare that data to see better what or how all this behaves.
Me on the left and he on the right
- Has thanked: 20834 times
- Been thanked: 10503 times
Cool thread everyone!
