The weather beeing so bad these last two months, this was the opportunity to take a plunge in the quantitative assessement of air-spaced etalons.
This work builds on discussions with Bob Yoeles, Oliver Smie (Beloptik), Serge Koutchmy (IAP) and Cyril Bazin (IAP).
But most of all, François Rouviere (co-author of Solar Astronomy) deserves the main credit and a big thank for establishing the formulae to calculate the FWHM, FSR and delta CWL of etalons from the mesurements.
The general line of the procedure is presented here. Sorry, the page still under work ...
http://astrosurf.com/viladrich/astro/in ... sting.html
The main interesting thing is there, with the measurement of a SM III-60 mm and a SM III-60 mm RichView etalon:
http://astrosurf.com/viladrich/astro/in ... ing-2.html
Both are excellent with a FWHM < 0.6 A, the SM III 60 mm behing slightly better and a thad more uniform.
This is preliminary, but still very encouraging. I plan to test two SM 90 mm in the coming month.
In a nutshell, the idea is to use the etalon as a Fabry-Perot interferometer, the etalon receiving diffuse light from an Ha light :
The system of interference fringes is observed visually (qualitative evaluation) or with a camera (for quantitative estimation).
After some least-square fitting with Lorenztian functions and some math, the FWM, FSR and delta CWL can be derived :-)
