DIY Solar Scintillation Seeing Monitor with FC support
- rsfoto
- Has thanked: 9723 times
- Been thanked: 5773 times
Re: DIY Solar Scintillation Seeing Monitor with FC support
I have to start all over again as it looks like I fried my LMC6484 due to improper measuring while the Arduino was running. The values from yesterday where too low and so I tested the circuit which I still had on my breadboard and they looked much more logical.
Also the idea of the 3 capacitors un paralel was not good. I finally got my 3.3 uF capacitors and exchanged and it stabilized.
Well I still have holidays and so no problem. At least I have something to do.
saludos
saludos
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Ooops, can happen. Few months ago i fried a nano Arduino in my focus controller while doing some modifications.
regards,
regards,
- rsfoto
Yes, " Sh...t happens " and I should have used a socket instead of Hot soldering the LMC6484 onto the board
Well makes me have more experience for the future
- rsfoto
Went back to the bread boarded circuit and added a LED Bar for the visual identification while the SSM is working.
Video of 1 minute which crunches a real time video I took during 18 minutes.
https://vimeo.com/249602522
Below the circuit on the bread board
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
sorry for my English translators google
- rsfoto
Hi Paul,
Is that in real time and are you reading at an iteration rate of 1000 ? I am just starting and learning to program the Arduino so I still have a long way to go.
- banjo
no it's just a simulation before integration into my software, I find that the colors are more meaningful than the numbers.
blue very good
green ok
red useless
a small gift of January 5 , not very stable, the sun is low and the wind is very strong in France
blue very good
green ok
red useless
- rsfoto
Thank Paul and yes you are right. My bar when many LED on is bad and few LED on good. At the beginning it is difficult to judge but with the time one gets used to it.banjo wrote: ↑Sat Jan 06, 2018 10:47 am Hello,
blue very good
green ok
red useless
LED 1 and 2 I use them for signalizing Sun intensity
Led 1 Sun intensity and > 0.5 to <=1.0 then OK and ON else OFF
LED 2 blinks when Sun intensity > 1.0 abs so I know I have to adjust. It happened to me that I had to readjust because the adjustment the day before was again to high and as I see the sky today I think I have to readjust.
The little BPW34 was delivering yesterday up to 3 mA ( 3000 uA ) of current.
and then LED 3 to 10 are as following
LED 3 -----------< 1.0
LED 4 > 1.0 --- < 1.5
LED 5 > 1.5 --- < 2.0
LED 6 > 2.0 --- < 2.5
LED 7 > 2.5 --- < 3.0
LED 8 > 3.0 --- < 3.5
LED 9 > 3.5 --- < 4.0
LED 10 > 4.0 ----------
- PDB
Excellent idea!!
immediatelly started working on my Solar Monitor again Now still someting similar to add for input value
- banjo
Hello everyone,
Paul, that's exactly what I would like to do, bargraph input & output super.
Your software is extra !!
Is it possible to have it?
- PDB
Yes it is possible but this version is not completely ready yet ... and only Linux at the moment, although I am working on a port to Windows (would like to port it on OS/X as well, but no machine, and think my wife will throw me out if I buy yet another computer )Is it possible to have it?
I will let you know when it is ready and tested. The automatic trigger of video capture will (should) work wit Planetary Imager and FireCapture.
- banjo
thank you Paul,
I am with Win7 and do not know much in programming.
I'm waiting for your final version with pleasure.
- PDB
Paul,
have sent you a private message about this. (A windows test version is now available)
P.
- banjo
Hello everyone,
thank you for this message, sorry not to have answered before, I'll try as soon as the sun will show.
In the south of France just December 5th and January 5th really good, if not only rain and clouds.
- Has thanked: 174 times
- Been thanked: 619 times
Any updates on this project?
Any changes/ improvements over the past three years?
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
DIY SSM Arduino pdf file please upload ?
Original file for DIY SSM - https://www.ecu.edu/cs-cas/physics/uplo ... final2.pdf
I can't find this now, can anyone please upload this, as I want to pursue this project for myself ?
Many thanks
Magnus
Many thanks
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- PDB
suppose you mean this?
Never trust the cloud to keep data
- An-Inexpensive-Solar-Scintillation-Seeing-Monitor-Circuit-with-Arduino-Interface-final2.pdf
- (604.24 KiB) Downloaded 258 times
- Radon86
Hi Paul !
Thank you very much Paul. You saved me a lot of work and research.
Great !
Magnus
- Radon86
Hi All,
I am starting to tackle this project and build my own DIY SSM. Does everyone use one or would like to own one ?
I wonder what percentage of solar imagers actually use a SSM connected to FC or not connected to FC (FireCapture)?
I am thinking if someone could build it, would some of you be interested to buy it if it was a lot less expensive than the ones made by the mainstream company for 350 dollars/euros?
Magnus
- Has thanked: 20813 times
- Been thanked: 10487 times
I have an SSM, used to use it connected to FC, rarely use it now, just gauge the seeing by eye and experience.
- Radon86
Thanks Mark,marktownley wrote: ↑Tue Apr 27, 2021 6:14 pm I have an SSM, used to use it connected to FC, rarely use it now, just gauge the seeing by eye and experience.
That is very interesting. Sort of tallies with what I can tell from my own eyes. I am getting better with experience.
I will see if I can build one inexpensively, could be fun ?
Magnus
- BGazing
- Has thanked: 289 times
- Been thanked: 353 times
Welp.
A friend made me one using the sketch kindly provided...but it won't connect to the Windows program. It connects on his Windows 7, but won't on my Windows 10. What givess?
Otherwise it works with its little display...just won't connect.
Lunt 80MT DS, 533/1600/462
- The Sun?
- Been thanked: 11 times
Depending on what Arduino (or clone) was used you might need to install the usb-serial chip drivers (FTDI, Silicon Labs, Prolific, Arduino ....).
- BGazing
Spent around 5hrs seeking all sorts of solutions...and then reinstalled SSM out of desperation...voila. Go figure.
- Bastelhannes
- Has thanked: 83 times
- Been thanked: 138 times
I would like to build/use one, but I could never get me to like FC. Don't get me wrong, it is a nice program. But it's like a partner, you do not fell in love with everyone you meet in the pub (oh, what a nightmare).
My greatest fear is being married alive.
- Has thanked: 288 times
- Been thanked: 244 times
Only very briefly and things seem to be woking - although I am not sure about accuracy yet. I also marked up the breadboard photo in the initial paper to reproduce that layout. Attaching in case it's helpful to others. The Arduino code needed some alteration to work with the Uno as well.
-Derek
