lunt 50 mod
DSobserver
Been thanked: 19 times
lunt 50 mod
Post by DSobserver »
After many years dealing with inconsistent Ha area with my PST mod, I decide to move to a lunt 50 mod.
Luckily my152/900 scope is close to lunt 50 f/d ration, so no barlow is needed!
I was also looking for a fully screw system.
here is the result :
As you can see I also take the opportunity to connect a jmi focus system far better than original one!
Has thanked: 20818 times
Been thanked: 10487 times
Re: lunt 50 mod
Nice mod there!
Has thanked: 156 times
Been thanked: 893 times
Re: lunt 50 mod
Post by Valery »
The sweet spot size should be about the same as with a PST Mod-2. Both etalons are air-spaced and both have the same working diameter - 20mm. The only advantage is the possibility to move the CWL of the etalon to blue and red wings.
zorgdotnl
Has thanked: 1 time
Been thanked: 5 times
Re: lunt 50 mod
Post by zorgdotnl »
That's cool!!! :bow :bow :bow Do you have some images taken with it?
DSobserver
Re: lunt 50 mod
yes here : http://www.webastro.net/forum/showthread.php?t=147279
valery,
you're probably right but it is less detectable and scope is f6 working vs f10 for pst mod!
DSobserver
Re: lunt 50 mod
just measured : 24mm!
Re: lunt 50 mod
DSobserver wrote: Wed Apr 19, 2017 6:56 pm just measured : 24mm!
Always very useful to know, thanks! :)
aboy
Re: lunt 50 mod
Post by aboy »
DSobserver wrote: Sun Apr 09, 2017 2:52 pm After many years dealing with inconsistent Ha area with my PST mod, I decide to move to a lunt 50 mod.
Hello DSobserver I have a question:
Do you think the specs of your 152 are the same from the TS152 telescope? https://www.teleskop-express.de/shop/pr ... uszug.html
I have years trying to do a PST modification but I fail in my first one and got disappointed of myself and stop trying that. But, I like the ide ato make a 152 telescope and lunt modification.
If is possible can you share some more pictures and specs of your modification?
I'm sorry if I bother you with my request.
Thank you :bow
"I'm enough of an artist to draw freely on my imagination. Imagination is more important than knowledge. Knowledge is limited; imagination encircles the world."
--Albert Einstein, October 26, 1929
EQ:
Double stack 60mm Coronado ( pre-meade ) H-alpha filters with a 15 blocking filter.
DMK 51AU02 the imaging source Mono CCD camera.
Orion Short 2x Barlow.
Explore Scientific 102mm f/7 Air-Spaced Triplet ED Apochromatic Refractor Telescope.
Astrotelescope ( Planet Killer ) 102mm f/11 hand corrected doublet. Refractor Telescope.
Losmandy - G11 ( Gemini 1 )
FireCapture, AutoStakkert 2, PixInsight, Registack 6 and Photoshop CS 6.
DSobserver
Re: lunt 50 mod
hello
TS scope is same as tecnosky one
lunt 50 mod is really easy it is a M68 screw same as the focuser from the scope! You'll immediatly get 95% of the mod.
Next if you want to change lunt focuser and get perfectly same distance between focus point and filter, you'll need some specific adapter.
I could comare visually this mod with 8" HAT : my "cheap" mod was impressive!
DSobserver
Re: lunt 50 mod
of course I also add an internal 75mm erf!!!
Re: lunt 50 mod
Hmmm. M68 on the lunt 50. That does make things interesting in the mod department...
aboy
Re: lunt 50 mod
Post by aboy »
DSobserver wrote: Fri Oct 27, 2017 7:23 pm of course I also add an internal 75mm erf!!!
DSobserver wrote: Fri Oct 27, 2017 7:22 pm hello
Cool. I have save for a TS telescope I do need to buy it.
About the focuser for the Lunt. Which focuser are you using?
Can you post more pictures from your mod?
I'm really interested because my last PST mod was a disaster and I ended mess up the etalon.
I don't have a internal ERF but I have a 100mm ERF.
Also I notice that in your picture you using a Coronado blocking filter.
Please let me know if you can post more pictures and if you can add more specs on the focuser and the mod. I'm drying to do a mod that actually woks for me.
Thank you
EQ:
aboy
Re: lunt 50 mod
Post by aboy »
marktownley wrote: Fri Oct 27, 2017 8:46 pm Hmmm. M68 on the lunt 50. That does make things interesting in the mod department...
I'm sorry.
What do you mean with that?
EQ:
Re: lunt 50 mod
There are lots of M68 adapters available...
https://www.teleskop-express.de/shop/ad ... /OK/page/1
aboy
Re: lunt 50 mod
Post by aboy »
marktownley wrote: Sun Oct 29, 2017 6:06 pm There are lots of M68 adapters available...
EQ:
DSobserver
Re: lunt 50 mod
Hello
For me bf10 or 15 are clearly the best ones on the market : brightness and contrast
Regarding Focuser for me Lunt hélicoïdal Focuser is a real Che..
I had a Jim motor Focuser at home and asked for an adapter
In your case I wouldn’t focus to much on this part of my mod otherwise you can go for this one :
https://luntsolarsystems.com/product/1- ... h-focuser/
Again it’s the most important easiest mod : unscrew ref Lunt filter and screw it on ts scope at minimum focus point = done!
Regarding erf I fix it in the Focuser tube
You’ll easily find on solarchat how to fix yours!
I ve no access to my scope for the moment....
Re: lunt 50 mod
I've just got a Lunt50 myself - no plans to mod it at this stage, just full disks, but to add to the discussion, the thread size at the focuser side of the Lunt etalon is the same as that on the back of the Daystar Quark, so there are plenty of off the shelf adapters (eg this one http://astrograph.net/epages/www_astrog ... ts/AGRAQT2 ) to get a T2 fitting for various connection options...
DSobserver
Re: lunt 50 mod
good info!!!
aboy
Re: lunt 50 mod
Post by aboy »
Thank you guys.
I will start to buying the refractor maybe my next month and the other stuff I need and for last the 50mm Lunt.
I will let you know guys.
EQ:
paulf
Re: lunt 50 mod
Post by paulf »
Hi, new to the forum and solar imaging! I’ve got Lunt LS50THA with B600. Just checking I understand this thread, if I had a 152mm refractor then it is possible to remove the objective and tube from LS50, screw directly into the refractor focuser, install an ERF, and then I’m good to go? Or would there be other upgrades needed, like moving to B1200.
Re: lunt 50 mod
Valery wrote: Wed Apr 12, 2017 8:20 pm The sweet spot size should be about the same as with a PST Mod-2. Both etalons are air-spaced and both have the same working diameter - 20mm. The only advantage is the possibility to move the CWL of the etalon to blue and red wings.
Very true Valery. I think I will give my lunt50 etalon unit on the back of the HaT, it should just screw on with the correct adaptor.
Re: lunt 50 mod
Post by Valery »
marktownley wrote: Thu Jun 21, 2018 9:47 pm
Which etalon did you mean? LS50FHa? or from the LS50THa ?
Re: lunt 50 mod
The pressure tuned module from the lunt50 telescope - use it in a collimated beam.
DSobserver
Re: lunt 50 mod
paulf wrote: Thu Jun 21, 2018 8:48 pm Hi, new to the forum and solar imaging! I’ve got Lunt LS50THA with B600. Just checking I understand this thread, if I had a 152mm refractor then it is possible to remove the objective and tube from LS50, screw directly into the refractor focuser, install an ERF, and then I’m good to go? Or would there be other upgrades needed, like moving to B1200.
Basically yes but all depends on what scope you are talking about!
Larger bf would be better
Prefer coronado 10 or 15
paulf
Re: lunt 50 mod
Post by paulf »
DSobserver wrote: Fri Jun 29, 2018 3:09 pm
Thanks for reply, don’t have a refractor as yet, but just thinking ahead.
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Re: lunt 50 mod
Post by krakatoa1883 »
A very interesting discussion as I am also considering a LS50 mod. I have few questions if someone would be so kind to answer:
1. I assume the mod is fully reversible that is I can have back the original LS50, am I correct ?
2. Is the red cylinder with the PT knob simply screwed to the LS 50 white tube ? can they be separated easily ?
3. Which M68 adapter would I need for attaching the LS50 rear part to the telescope ? has this part a male or a female thread ?
4. I have seen in the above image a Coronado BF replacing the Lunt diagonal, is this replacement necessary ?
Thanks in advance
antonello
Been thanked: 17 times
Re: lunt 50 mod
Post by antonello »
After a long time, during which no one knew if the Lunt 50 had a lens with a single lens or an achromatic lens, I discovered from this image
lunt 50.jpg (236.86 KiB) Viewed 5852 times
that even the Lunt 50, like the Lunt 60., seems to have a objective with single lens, and therefore the use of the Etalon of the Lunt 50, together with the two lenses of its collimator, used on a new telescope with an big achromatic objective, will not allow to obtain, in h-alpha, all the quality of the new big achromatic lens ... :(
solarchatted
Has thanked: 12 times
Been thanked: 10 times
Re: lunt 50 mod
Post by solarchatted »
What an interesting discussion.
I am newbie on Solar and still deciding if to get a PST new [second hand is rare to find they go like cakes - obviously affordable!]
But I have been thinking to jump forward and get a Lunt 50 and then 'in the future - not now' possibly modify it to use on my AR152 988mm F/6.5.
What do you think - experts?
I am getting older and Solar would be an 'easy' addition for later years.
For now I am going to play a bit with White light only - just to get the hang of it again.
Thanks for your time
SolarChatted
https://astronomo.space/my-images/the-sun/
https://www.youtube.com/@Astronomo_Space
Solar Gear:
Bresser AR90/900 + PST mod + SW Auto Focuser ...
Sometime I use Explorer Scientific AR152/988 + Used once only... Altair 2" Solar Wedge (very good indeed)
Will try and do it justice when I can with the help of various filters, Baader 1.25" Solar Continuum 10nm is one.
SW 72ED Pro - fixed 'stock faulty' focuser ... 'I think' !
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Re: lunt 50 mod
Post by GreatAttractor »
antonello wrote: Tue Sep 04, 2018 10:35 am even the Lunt 50, like the Lunt 60., seems to have a objective with single lens
Hmm, interesting. Where does the image come from? I just double-checked my specimen (purchased in 2015) and it seems to have a doublet. I mean I didn't disassemble it, but it shows two upright minified reflections of my phone's LED when I hold it close, the same as my 90 mm achromat's objective.
Definitely! You will find some successful mods here on the forum. Mine are here and here.
My software:
My images
antonello
Re: lunt 50 mod
Post by antonello »
Hello GreatAttractor
I found this image on internet...
It is not a photograph, is a drawing that can not solve the mystery.
It seems that only Lunt knows if the objective is single or achromatic :-)
The number of reflexes is not significant, even a single lens produces two reflections, like a glued doublet.
I still would like to know if the 60 lunt and the Lunt 50 have a single or achromatic lens.
You can easily solve the mystery without disassembling the lens by looking at a tree far away with your Lunt 50 without the etalon mounted. Can you do this? Thank
Re: lunt 50 mod
Lunt50 is a doublet.
krakatoa1883
Re: lunt 50 mod
I disassembled my own for cleaning, it is a cemented doublet (front is positive, rear is negative).
antonello
Re: lunt 50 mod
Post by antonello »
Hello,
many thanks for the information.
Therefore the Lunt 50 Ha has an achromatic objective, and the image I posted was misleading. On the contrary, the lunt 60 Ha has a single lens
lens, as it is clearly written in this image
Some time ago I wanted to buy a Lunt 60 Ha to use it to see whole sun in Ha, and cannibalize it, using only the etalon group, on a large diameter achromatic. I did not buy it because I saw an image in which it seemed to have a objective with a single lens. I have then thought of buying a
Lunt 50 Ha, but I did not do it for the same reason.
I still wanted to get the same result and bought a Lunt 35 secondhand. I checked that this tool was little more than a toy and I worked to get something better.
With the Lunt 35 etalon I obtained a "Lunt-Zeiss 50", using a Zeiss achromatic lens 50 mm, f: 540 mm (teleminor) and two simple lenses from catalog for the collimator (-300 mm and +300 mm).
This is the result
The etalon group thus obtained can be placed on any telescope f: 10 approximately. I use it often on a Tal 100, when I want to see the protuberances in detail.
This is the instrument
I am very happy with the result.
Re: lunt 50 mod
That's a sweet setup!
antonello
Re: lunt 50 mod
Post by antonello »
If it can interest someone ...
Here are the individual lens of 42 mm diameter f: -300 and f: +300 in my etalon Lunt 35.
Here is the simulation of the quality of this collimator with three different objectives.
Perfect lens 50/540
edmund50/500 achromatic lens
Single lens 50/500
We can do a reverse test.
Let's take the "telescope-optics.net" single lens Ha solar telescope, diameter 100 mm f:850 mm, with collimator for etalon,
https://www.telescope-optics.net/specia ... scopes.htm
This is the quality of this single lens telescope
If we now remove the single lens and put a perfect lens (apo or achro is similar), 100 mm f:1000 mm, we get a very bad quality
Re: lunt 50 mod
Interesting spot diagrams, thanks.
