Removing barlow from Quark
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
anyone tried to remove internal telecentric barlow from Daystar Quark?
I have a excellent Quark but in the next future I'd like to use it with a DK/Cassegrain F15 so I need a Quark without internal 4,3X barlow for using a 2x telecentric barlow
Tks
Ale
Tks
Ale
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- Has thanked: 20819 times
- Been thanked: 10489 times
Re: Removing barlow from Quark
Mine just unscrews...
Mine also unscrewed, but it required a bit of force and a "boa wrench", because the thread was sealed with what looked like red locktite.
Frank
Frank
- sulcis2000
Tks Frank & Mark. Can you show me a picture of Daystar Quark without barlow?
Ale
Ale
Alessandro Bianconi
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- nickatnight
I think Daystar may have added a screw on newer models. Mine has a bit of give if I try and twist it, but a screw on the back right by the joint seems to prevent the turning.
- IMG_0207.JPG (1.91 MiB) Viewed 18896 times
- IMG_0205.JPG (1.61 MiB) Viewed 18896 times
- sulcis2000
Tks a lot Mark for your contribute!
Ale
Ale
Alessandro Bianconi
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- Has thanked: 175 times
- Been thanked: 429 times
One question is how much of the blocking filter comes off with the Barlow. If I were Daystar, I would have put the blocking filter before (objective side of) the Barlow so that I could use a smaller one, which would mean it should unscrew with the Barlow.
George
George
- Has thanked: 1188 times
- Been thanked: 1382 times
Anyone with experience with removing the barlow from a more recent Quark, with he screw/bolt on the side? Any issues? If you take the barlow out, does it still have its blocking filter intact? Would really like to know if you can basically take the barlow out and have a quark combo essentially, and then pair it with other options.
Hi George. The blocking filter is on the end of the telecentric.
- sulcis2000
Anyone has tried a Coronado BF (BF15 or BF30) instead of the original one of the Quark?
Alessandro Bianconi
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
Yes, it works, but must be before the telecentric.
- sulcis2000
Tks Mark ;-)
Alessandro Bianconi
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
- Has thanked: 57 times
- Been thanked: 1204 times
to LTHB
how did you get black main ring off of red etalon body?
I see a funny looking screw that has a pin like center
i assume you need a special hex wrench ?
does it have a name?
thx JP
interesting topic
thx JP
interesting topic
I'm not quite sure what you mean: two of the four screws (upper left and lower right) on the left hand side of the second picture in my last post? If yes: I didn't remove these screws/the black ring so far, so I cannot really tell if they can be removed without damaging the filter.
However, for unfamiliar (to me) screws I usually check Wikipedia, i.e. here: https://de.wikipedia.org/wiki/Liste_der ... pfantriebe
The two screws in the black ring look to me like number 12 from the bottom of the long table (called "Torx Plus mit Stift (5 Point Security)") in the wikipedia entry. This type of screw seems to be missing in the English version of the wikipedia entry, or at least I cannot find it there, but I think they are called "5 point Torx" or "5 point security Torx" or something like that in English.
Frank
Frank
Yes security torx screw
Do they come off by turning left
But is it t10?
But is it t10?
Sorry, I misunderstood your question! Yes, you have to remove one screw before you can separate the red etalon body from the main black ring (the two parts on the lower left and in the center of the second of the three pictures in my post above). This screw is on the side of the red part, I removed it months ago but cannot find it right now, so I cannot check what type or size it is. I recall that I had to use some force to break the locktite (I think I used a ratchet wrench - bit sets for 5 point Torx are available on ebay, amazon etc.), but otherwise there was nothing unusual about it.
- The Sun?
Yes I just now finally managed to take my standard original non-combo Quark Chromosphere apart, the red metal Etalon body and the black metal Telecentric / 4.3x "Barlow" were held together with a TS8 size Torx anti tamper 5 sided (pentalobe) screw that I had to get a screw bit set for (Silverhill brand). I used a 6.3mm hex drive type ratchet screwdriver with handle of about 1.5" diameter in order to have sufficient torque (and I pressed hard into the screw) to be able to undo the screw without stripping the head. The screw was on very tight from the factory, so presumably threadlocked. The black metal bodied "4.3x Barlow" assembly was then easily able to be unscrewed from the red Etalon section. There was no threadlock on the threads joining the red Etalon assembly and black Telecentric together.sulcis2000 wrote: ↑Mon May 01, 2017 9:03 pm Hi
Tks
Ale
I do however find it impossible to separate the black 2" part of the "Barlow" from the black 1.25" part. I even tried a strap wrench but it's on too tight.
Best Regards,
AG
- Has thanked: 3317 times
- Been thanked: 1907 times
If the Telecentric has been taken off how can a new Blocker be before the Telecentric?
Do you mean in place of the Telecentric?
Rod says there is just a red filter at the back end, is that so?
Andrew.
Andrew.
