Now I have a new ITF, things are 'clear' !
What I wish to do is the obvious mod to use PST as a Quark and use it on various scopes, including my AR152 F/6.5
My 'practical' questions:
1. Do I need to warm tube to unscrew it from PST? I do not wish to break anything or scratch tube!
2. I do not wish to cut original tube, what do I use that fits or step-down adaptors or even if I need to use PTFE ?
3. I do also not wish to modify any telescope [if possible] and simply modify PST and use it with a standard 2" nose piece, any clear procedure to do it 'clean' and without ruining the PST ? - i.e.so I can re-mount it, in case I need or want to re-sell it in the future, or use it as portable - I am a keeper!
4. future questions will be which filter to use in front of the larger AR152, that does not break the Bank?
I plan to mainly use it with my smaller scopes 72mm and 80mm and in theory I will not need the front filter and maybe just use a good Baader IR/UV one!
Maybe a 100mm [cost much less] and use it with all scopes and make a reducer for 152mm and still use 100mm
5. Is it really worth the hassle and expense? - well, it is if one does not wish to buy a DS expensive adaptor for PST and still be in the 'small' magnification.
This might be another solution - https://www.meade.com/coronado-30mm-blo ... rough.html - Straight through ?
You cannot have the best for very little and since I will never be able to afford to buy 'anything' expensive, I have to do as much as possible myself and using the PST with a new ITF and still a little 5-6mm hole!
I am really in a limbo, desiring something more powerful [when needed] and be able to use my telescopes without buying a Quark - I still need to see, how long they actually last - in particular the electronics!
In short, I need the less expensive and but DIY doable solution to use PST SS as a Quark, over my telescopes - AR152 F/6.5, AR102SX [short tube!] and SW 72ED.
I could use my old SW ST80 and modify it - I never use it now - but is is F/4 or get a cheap ~ £. 70 70mm F/10 and modify it as others have done.
It is all about a balance of money spent and 'real' results worth doing a mod or not and look at what others can afford to do!
Thank you for putting up with me.
Mauro
PS sorry if I might have mixed up anything, I am not stupid, but I am no expert in Solar and Optics
Mauro
SolarChatted
Finally found a little time to look and yes the best tool is the car oil filter tool [the one with a belt to avoid scratches], to remove PST tube.
Which way?
The normal anticlockwise movement? With left hand holding body [or vice with padding!] and right hand turning left or towards me if parallel in front of me?
I might try and make an adaptor, modifying what I can find sizeable.
Which way?
SolarChatted
Hi Mauro, have you tried unscrewing the gold tube by hand? I've had some PSTs that just unscrew with little force.
If you're going to use your existing scopes you will need to get them working at f10 for the PST etalon.
Mauro,
I have a write up available for the PST mod drop me an email address for a copy.
A couple of critical things.
The etalon assembly must be positioned 200mm inside focus.
The etalon works in an f10 beam. If the donor scope is faster (f5) the aperture will be reduced.
Adaptors, front and rear are available.
An ERF is recommended (front or internal) above 60mm aperture.
Hey Mauro,
Some PST's are a bear to open up and are glued. I have opened two of them now. One was hard. I scratched it up good. The other was easy, it just came apart. You can use things like a heat gun or hair dryer to help warm up bonds (glue) and gently work things until they give. The most important thing about taking apart a PST is to NOT ruin the etalon housing. It's delicate. After you remove the gold tube, you need to peel off the rubber around the tuner. There will be tape and a small screw. Mark where the screw was and the holes it lines up with so you can put it back exactly. But take all that out. THEN try and take off the etalon from the black box. This way you are not twisting the etalon housing and breaking that little screw, which will totally ruin the PST etalon housing tuner.
Ken (Merlin66) wrote the book on this. So check out his information.
Also, I have a log showing how I did mine, and what I've done with it. Also the adapters I bought from AOK Swiss and all that. More info here:
viewtopic.php?f=9&t=25420
Since you do not want to cut a tube and you're looking to do things inexpensively, I recommend you forget looking at big 150mm+ apertures. Instead, look at 102mm aperture achromats at best. You can get away with a Baader 2" HA 35nm filter as an ERF, or a Baader 2" Red CCD-IR Block filter as an ERF in front of the etalon housing using a 2" extension in front of it, in an unfocused beam of light to cut costs. The collimation lenses are F10 on the etalon, and require +/-200mm on both sides to reach focus. So you have to find a really short tube with a short focuser to avoid cutting a tube. But in reality you will need to just cut a tube most likely. Alternatively, you can get different collimation lenses to go to F8 or something. Another option to avoid cutting a tube is to get an F8 scope and then get a Baader Glasspath 1.25x corrector (typically used for binoviewers) to bring the scope to F10 natively. Then it will work for PST modding. Another option is to get a native F10 scope all together. Celestron's 102mm F10 Omni XLT is a great option and inexpensive. And again, you can block the heat with one of the 2" filters I mentioned just above. You will want to get a bigger blocking filter (Stage II mod), so a Coronado 10mm blocking filter is a good way to go. You are not likely going to use sensors much larger than 10mm anyways (mono sensors that is), so it should be fine. If you're at all worried and have larger sensors like M43 size, then get the 15mm filter. Since you're on a budget, I doubt these are options, so the 10mm filter will be good. Then, to match it, something like an ASI290MM camera or ASI178MM camera would be worth looking at.
Sorry for very late reply, I went on holiday and then back to work, I am now getting back to it.marktownley wrote: ↑Tue Apr 09, 2019 8:08 pmHi Mauro, have you tried unscrewing the gold tube by hand? I've had some PSTs that just unscrew with little force.
I did try - not too strongly - unscrew it by hand.
Then I go the leather puller and unscrewed it straight away and screwed it back in by hand.
SolarChatted
HiMalVeauX wrote: ↑Wed Apr 10, 2019 10:29 amHey Mauro,
Some PST's are a bear to open up and are glued. I have opened two of them now. One was hard. I scratched it up good. The other was easy, it just came apart. You can use things like a heat gun or hair dryer to help warm up bonds (glue) and gently work things until they give. The most important thing about taking apart a PST is to NOT ruin the etalon housing. It's delicate. After you remove the gold tube, you need to peel off the rubber around the tuner. There will be tape and a small screw. Mark where the screw was and the holes it lines up with so you can put it back exactly. But take all that out. THEN try and take off the etalon from the black box. This way you are not twisting the etalon housing and breaking that little screw, which will totally ruin the PST etalon housing tuner....
Sorry for very late reply!
I am thinking either use a Bresser 102sx I have - but is a fast one at F/4.5 or get a ... I have seen cheap 100mm F10 easily modifiable ... !
The Celestron's 102mm F10 Omni XLT seems a very good choice.
What do you think of the Bresser 102SX? It is very short?
I think the first thing to do is to get the PST block ready to be used and then start playing with scopes!
A lot to think about.
Mauro
PS thanks for the links!
SolarChatted
Any of the 100mm f10 scopes are excellent for PST mods.
I am 'slowly' getting along [time permitting] to understand 'the works' by testing and already the SCT focuser mod is better than PST standard setting - even using bath-tub splash-proof insulators as spacers within 1.25" adaptor to hold PST eyepiece holder!
With SCT focuser I already got rid of the PST block with prism that interferes with beam, in fact (as mentioned on another thread) I now have a clearer and brighter image as is ... but beam has intensified too.
One question, just to be sure - for the time being, is it OK to use a Meade series 4000 RED #25A filter + IR/UV in front of etalon at adaptor length - i.e. in out of focus beam?
I already used the #25A as it is with PST or SCT mod and it does help in certain circumstances - I guess when it hazy.
Then if necessary I will probably get a Baader 2" HA 35nm or a Baader 2" Red CCD-IR Block filter.
I understand also this way I will have heat currents ... not having an ERF in front of telescope ...
If I can get away with 25A, then next expense will be a 100mm ERF to use with AR152 (possibly).
I am just trying to have 2 scopes, PST standard (when needed) and a I can dismount PST and use (mostly) with a 100mm or the AR152.
I am not greedy, but I would like to put one foot inside the 'better' side of Solar.
Thanks for taking the time to help
M
See images with SCT mod - https://tinyurl.com/y5qfdrns - although it was clear, it was quite hazy and if I am not wrong used the RED #25A filter and got away with it ...
M
SolarChatted
I am in the process of doing the same PST 'Combat'.
Follow Merlins advice on removing the rubber ring and small screw. Two of us used a rubber filter wrench, held black box in vice and a small rubber filter wrench on the etalon. It moved when I used my hand on the Gold tube as well. Obviously its a lottery as to whether the gold tube comes off on its own or with the etalon even so. We managed to get the etalon off the black box.
I soaked the screws in the black box with ethanol for a day but I still wrecked one using a small rachet wrench and had to drill out the top. The grease on the prism slide migrates onto the prism and I wanted to put stops in the front of the black box and at the bottom of the blocker / eyepiece holder. We tried to get the eyepiece tube off. Only the top part with the Comb Blocker in came off. A blowtorch did not get the base to move. Rod had to turn up a little ring to push fit down the useless ribbing in the base and bodge on a repair washer and holding random rubber ring to make a stop. Looking down the Comb Blocker, with no front on the black box, there are reflections off the top and bottom of the prism so the stops help to hide those. Also as the prism is not coated there are lots of transmitted and reflected spots in the box. So I painted the front, bottom and lid Black2 and flocked the back sides where the worst reflections are.
It would be usefull if front ERFs are called DERF and intenal ones ERF and the actual Comb Blocker that as there does not seem to be a standard.
Refections of the Sun inside the telescope are an issue. Use on the Moon first, etalon only, to find the brightest reflections.
Then on the Sun look into the blocking filter with no eyepiece to see what reflactions there are.
In the Vixen VMC I had to stop stray daylight coming in, commercial Maks are not baffled well enough as they are struggling with fully illuminated field issues, and limit the light to whats being used.
Put on a long front baffle, put a baffle on the edge of the secondary, and the corrector lenses edges are not blackened, put a stop on the front of the rear baffle. Made a smaller one to start with and then found the Suns size on it and turned it down to that. With the black box and 5mm Comb Blocker you are observing off axis for proms so you do not want any other light to get in. I found that ribbed baffles in the SH Barlows used and the black box are useless. In the Barlows Rod turned them down to have forward and rear facing angled knife edges. An angle into the wall to act as a 'beam dump'. With the bit between turned down so the knige edge vignettes it and the sloping edge of the far knife edge then reflects the out of field light onto the Black2 wall opposite. For the black box Rod made a nice baffle after the PST etalon, bright reflections off the etalon as it reflects out of Comb light. You need to get to the point where there are just a few very thin bright rings, off the kinife edges, and the rest is black as possible. I have the Vixen and black box now so the Sun has a inky black background to the eye,imaging will probably show scatter, and with it just outside the field there is no light visible to the eye.
AOK Swiss sells standard and custom adapters. I had a custom front one to T2 made for my Vixen VMC110. I am about to order a standard AOK Swiss rear PST to 2" adapter for a DS with Bobs H-alpha filters, one for proms and 2 for chromosphere? We have tried a Omega Bobs 1.5A (0.15nm) as a Comb Blocker and it worked. Its narrower than the PST one. It is a cosmetic second so some variations across it. And allows the full etalon aperture to be used.
I have made the etalon into a 'Combat' by taking out the two lenses, they should be marked with an arrow or mark them and check which side the flat face goes. I have put a Omega Bobs 25.4mm 40nm ERF in the front. It blocks long IR the Baader 35 nm lets through and it has dimmer reflections. And a KG1 25.4mm in the back to protect the etalon. I have used the PST Combat on a 127mm refractor on its own, with black box on the back, with no issues. But I am using a 2" Baader IV-IR in the 2" extension tube set on front of the PST adapter about 13cm in front of the etalon as well to spread the heat rejection out. Good up to 7" I would think. I found a 48-43mm filter ring adaptor on the front worked to baffle reflections from the 7cm of focus tube in front of it. For visual I am using a 1.25" Beloptic UV-IR on KG3 in the eyepiece for additional safety.
MarkT says he only uses his 127mm once a month, in the UK so I am sticking with a Lunt 110mm DERF I bought SH. 100mm clear in a holder. You can use the PST with a telescope shorter than F10 it just vignettes it to F10. Just use a DERF or stop to suit or internal ERF, though the external DERF is better but more expensive.
You need to get a bigger Comb Blocking filter. Daystar use Andover filters 12.5 or 25.4mm as I recall. They are soft coated so need a good DERF/ERF up front to make them last and stored in a moisture free environment.
I am trying Omega Bobs 40nm 25.4mm ERF and one of his H-alpha 'seconds' filter 1.5A at the moment as the Comb Blocker.
On my 127mm F7.5 I tried a bodge to stop cutting the tube. I put a nose piece off a 2x ED barlow with T2 to 48mm infront of the AOK adapter / PST etalon and black box. With no PST lenses. I got a good image. Rod has tested Barlows at the position they need to be for the PST and black box on a double star and they give about 4x. So I was working at F30 straight through. Looks as good as Pedros images and with the Bobs H-alpha just dropped onto the Beloptik in the eyepiece good for chromosphere (needs to be in a tilting holder for Stage 2 Mod).
From the Daystar site the PST looks like 0.7A and with Bobs filter 0.5A.
The problem with the PST Etalon is it needs to be outside the focusser to tune it. So there may not be enough back focus when doing a Stage 1 mod as the black box needs 200mm back focus.
MarkT shared a cunning mod where you move the collimating lens up into the focus tube. There may be a slight issue with the 'collimated' beam drifting out?
On my Vixen VMC110 mod, PST lens vignettes F9.4 to F10, I gambled that I would reach focus doing that and I was lucky that it does, just.
Rod made me a push-in, masking tape filler, holder from an old barlow. And the PST Collimator lens held in a little nose piece Barlow holder with a plastic Celestron Moon filter holder pushed in to hold the PST lens, as they use 25.4mm filters. (Anyone found a Chinese metal holder for 25.4mm Moon filters?)
Rod gets a full sun with a 2250mm fl refractor through the PST. For rare good days I will try a F10 180mm Mak, fl1800mm, as it nearly fills the PST and using the full aperture helps reduce instrument angles for a larger sweet spot. All PST mods will only have a small sweet spot in the middle due to collimation off band, acceptance angles and instrument angles.
A stage 1 Mod does make things larger and have more resolution. Though the sweet spot if not central will drift out of view. You may need to centre the etalon, MarkT did make a custom ring but has lost the CNC file unfortunately.
You can use the PST as it is on any scope. With suitable DERF or ERF.
Move the collimator forward to save sawing up your scope to reach focus.
It vignettes less than F10 to F10. So you can use a 100mm DERF on the small scopes and the longer refractor for larger image.
You can use a weak barlow, Baader 1.25x glasspath seems popular, to make a faster scope F10.
Or use a shorter collimator and re-focusser on a faster scope to use its full aperture, matching singlets or achromatic doublets for better quality.
solarchatforum.com/viewtopic.php?f=9&t=24425&p=219615#p219615
For the PST as is MarkT uses a UV-IR to block IR as it softens the picture when imaging.
I use a 2" Beloptik UV-IR on KG3 to block all IR. With a 52mm to 48mm adapter.
www.diane-neisius.de/coronado_pst/index_E.html
An AOK Swiss front end adapter lets you do Stage 1 mods for £50ish. 48mm or T2.
You can move the front collimator lens forward to reach focus without cutting tubes down.
You can use a weak Barlow £95, or ES achromat? £75 on shorter F no scopes to reach F10. Remember to check its power used in front of the PST at its position inside focus.
Or you can replace the PST Collimator and re-focusser lenses to use all a shorter F No telescopes aperture.
You should block UV and all IR for your safety and to make Comb Blocker last longer.
Long IR KG3 or Omega Bobs 40nm 25.4mm ERF.
Andrew
Mauro
Andrew
Mauro
Just noticed your reply.
I thought it was not a reply ... there is no bold or italic to discern my typing to yours.
I will copy it it and do it, then I will see your answers clearly.
M
M
SolarChatted
BOLDED answers ... to help anybody else reading.
Andrew
Mauro
Andrew
Mauro
SolarChatted
At present, I have already dismounted all parts and already done a SCT focuser Mod and it is very nice, but with a 'wobble' PST eyepiece into an adaptor.
See this post: viewtopic.php?t=26069#p235640
I am waiting for AOK Swiss adaptors posted yesterday and then I will play with my AR152 - which already has a home-made 100mm mask with added tin-foil to further reflect The Sun back.
I will report as soon as I have done my first 'learning' test - yes, I will also test focusing with a piece of paper before I fit any thin on the scope - including my eyes!
Notes on SCT focuser mod - I wish I had more time doing tests properly.
Yes, I have read somewhere about the Baader 1.25x glasspath - interesting.
Yes, I have used a 2" UV-IR filter and it seems to soften when imaging ... true!
SolarChatted
ADDITION: while having dinner and talking with my wife, I just remembered one 'possibly important thing - in my case' ... do I have to take the lens/lenses OFF the Tuner?
If so, tomorrow I will get a couple of plastic sealed bags from workshop and at night take them off and mark with pencil which one if front and back + which way if forward on both sides -if there are two lenses.
The kind of in focus but not really made me think of this, which I read somewhere, I do not remember in which case you should take it off, although Beta from AOK swiss mentioned Tuner having a 25mm FL - if I am not mistaken.
I finally had got the AOK Swiss front adaptor and also got the back one - supposed to be used with a BF10-30 etc.
I instead used the PST BF6 and placed it in the middle of the back adaptor.
I added a 3rd threaded hole and replaced original thumbscrews with 3x nylon ones - I also added some padding around the PST eyepiece [BF6] unit and used the 3 thumbscrews to centre it - when I can afford a BF10, I will get it.
I masked AR152 down to 100mm using a cardboard and covered the front with aluminium foil to reflect the sun.
I made it in a way it does click on the 3 internal adjusting screws [over the lens] and put dew shield back on as further holder - that works well.
Then fit 178M [+IR filter] + PST eyepiece holder [BF6] fit as above + back adaptor + PST tuner + front adaptor + IR filter + Meade 4000 Red filter.
The whole thing seems OK and not getting hot, just a bit worm and I tend to put the AR152 lens cap on once in a while [yes, I know I will get hot currents].
Having said that, I can get a 'sort of focus' with AR152 focuser out at about 31mm and of course I get a lot more photons and I tend to keep camera between 1ms-7ms - gain minimum [100] using Sharpcap.
BUT ... it is not a very good focus and I am guessing either the 100mm is too much or the PST eyepiece holder [BF6] is too much in or both!
I have tried to pull out the whole 'lets call it Quark!' about 1.5-2cm and focus seems slightly better.
I also pulled the PST eyepiece holder out about 10mm - no change.
Also tried adding AR152 star diagonal to give it more distance - no change.
I also tried AR152 visually [same tests as above] and the same thing happen, I focus at bout 60mm [focuser out] using a Zoom at 24mm.
i.e. PST + SCT focuser mod I tried was much better, in fact and as expected it bettered PST altogether, by getting rid of the black box!
The other day I caught a Prominence and I did take a short video - see here the one called PST mod 2.5 ! - https://astronomo.space/my-images/the-sun - you can see there it cannot focus properly and I am not that far off too.
Bear in mind that day it was very hazy and you can see gain is too high, I wanted to see if I could get this small prominence and I did!
As mentioned a few times, I am no expert on optics.
Any idea what I am doing wrong?
Thanks again all of you for helping me getting there and sorry if I take sometime to reply.
Mauro
Mauro
SolarChatted
It will be all about spacing distances, this will be key. Some pictures of setup will help figure out what is going on.
Here is an image
I tried various distances for PST eyepiece holder and front 2" Tuner adaptor.
The focusing was around 31mm focuser out - going further back or forward was going out of focus.
The focus was not 'clearly' totally in focus ...
I am pleased I do not need to get lenses out of Etalon, therefore must be distances.
At present AR152 should be F/9.8 and normally - if am not wrong - the 178M focuses at around 32mm [possibly with the star diagonal at normal 152mm F/6.5.
Mauro
Mauro
- PST_MOD_2-5.jpg (79.74 KiB) Viewed 1258 times
SolarChatted
UPDATE
Today I managed to have an hour or so, to do some more Visual tests - Sky was clear enough for ab bit.
For what I gathered:
Problem 1 - Focusing
I added my 35mm Revelation 2" extension [to the setup in above image - before the Etalon] and it did focus a bit better with focuser about 12mm out [if I remember well].
I have been able to 'barely' see a nice thin Prominence [south for telescope].
I guess I need to get a 25mm 2" as it might be better and probably focus at 21mm focuser out.
Tried a 2x shorter Barlow on it [without 35mm extension] for a few minutes and it did barely focus - I am going stupid here.
Problem 2 - Reduce intensity
I believe I need a better/tighter RED filter, maybe the Baader but that costs - same with a 35nm Baader, better put money away for an ERF then - at least I will have the correct [external] filtering, no hot currents and SAFE ... in about 10 years time!!!
Sun light is way too intense as I cannot see any surface at all, never seen surface with this mod - I barely managed to see surface using 178M last time I tried
I cannot afford 100mm ERF, i.e. it means I will have to leave this mod for the time being and go back to PST mod 1.5! SCT focuser ... but this time use the self-built Quark!
Before that, I wish to re-test with 178M and the 35mm extension to see if it is in fact better with camera as well - probably better than visually, as I can adjust intensity.
There are sometime reflections and I guess it is to do with the RED + IR/UV filter filter before the Etalon = a blooming cheap mess!
I hate it when you cannot do things properly.
Will have to try.
Pity I cannot afford to use my AR152 - the best of all I have for The Sun !
This is not even time to try and sell what I do not use, a lot of people is with NO money, in need to feed the family first!
Sorry for crying!
It reminds me of an Italian 'humanity' film: 'We have only crying left'
Will have to try.
Sorry for crying!
SolarChatted
I think you need to review the basics of the PST mod.
1. The front of the etalon must be positioned near as possible at -200mm inside the prime focus of the donor scope.
2. The final focus will then be very (very) close to 200mm behind the etalon assembly.
Check your fitting/ settings to see how close they are to these numbers.
You cannot just put the PST Etalon assembly with the AOK Swiss adapter on the front of the focusser in a normal commercial telescope. It is very unlikely to have 200mm and the adaptor length in-focus from the position where a normal Plossl say is in focus on the Moon or a star. The Collimator will not be producing a collimated beam correctly where you have it.
There are only two ways I know to use a commercial scope with the PST Etalon without cutting some of the tube holding the focusser off.
1. Move the first lens in the PST Etalon assembly up the tube so that with the PST adaptor in the focusser and using the Black Box first in Stage 1 Mod mode you can get an eyepiece to show a focus on the Sun. Using the Black Box you are close to being 200mm after the Re-focusser lens.
2. Remove the lenses from the PST Etalon assembly and put a barlow before it. I tried a 2x Barlow and it worked. Because it was 200mm inside focus rather than 100mm I got 4x and my F7.5 worked at F30. It looked OK. F40 is ideal for an air-spaced etalon like the PST not in a collimated set up.
If you use the telescope focusser to get a moved Collimator lens 200mm in front of focus you need another focusser after the re-focussing lens, as in a Stage 1 Mod or an additional focusser in a stage 2 mod as above, so you can get an eyepiece or reducer for imaging to focus on the image 200mm behind the re-focussing lens.
In the original PST the Gold tube is made so the Collimator lens is fixed at 200mm insode the focus of the 40mm objective.
Andrew.
Andrew.
Andrew.
Andrew.
Hi both of you thank you for your time.
Yes, I got it now!
I am back to ... I cannot make or have a friend that can make me a flange to replace current one on AR152, so I can fit focuser 'possibly' 100mm more inwards.
It looks like it is time to save for a Lathe - second hand and make ALL adaptors myself - something I should have started about 20 years ago, as the flange is very large and most 'new' low-cost Lathe are allowing max 50mm width of any aluminium blocks to be worked on.
OK, I will exhamine what I can do myself once again and report.
I hope this threads will help others.
Yes, I got it now!
SolarChatted
Hi again
Just to keep updated - for others too, that have no previous knowledge/studied Optics and need help understanding.
Yes, it is the obvious ... the Etalon was off ...
I managed to push-fit Etalon/Tuner [including AOK Swiss adaptor with 2" IR/UV + Meade 4000 RED #25 Filter at the end of the focuser tube [internally] by simply adding spacers and slightly forced fit it in perfectly.
It actually is ~18.5cm from edge of 2" - 1.25" reducer, then added my home-made PST Eyepiece holder unit reducer and that is about another 6-10mm to the PST ITF [at the base of the PST eyepiece holder].
I tried visually with a Seben 12-24mm Zoom, 25mm eyepiece Kernel 8mm etc. - I also added a second 1.25" IR/UV filter at view side to further reduce rays - you can see there is a difference and that means I really need to get a ERF [if I can afford a 100mm - that is expensive] in front or get a 2" Baader RED/IR filter and fit it together with my RED one to increase filtering.
Anyway, I finally see some surface and much clearer Prominences - actually very nice visually - wow!
I then decided to get Laptop out with 178M and taken some images, but it was very hazy and mostly cloud-running weather here.
I dismounted AR152 F/6.5 focuser a few times to slightly adjust Etalon Tuner which was already nearly there and finally got a beautiful group of prominences. If I am not wrong they were South-West of SUN.
When I get time I will check if images are decent enough.
I can still see The Sun is VERY strong indeed and will need a good ERF, but first I need to solve the Etalon position - obviously cannot stay inside!
I do not think any modification would help much - you cannot really move focuser much. I can see even if [as I thought to try] I make a thick Plywood flange, focuser will only be 55mm inside - not much for Etalon - but I could still try to see what happens.
I might just remove lenses within Etalon and try a 2x Barlow - but adding optics will make things worse.
Then, last resort and easier is to get an F/10 telescope and cut it!
Mauro
Mauro
SolarChatted
What make is your AR152?
Aeries D-ERF
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
Whhhhooooaaaaaaa!!!! DANGEROUS! This is absorptive filter, not dielectric. Stop using it, and don't use the PST mod until you have proper filtration / ERFs. This filter WILL crack and given you are using visually worries more.
