Page 1 of 1
Getting better...Sunspot with 152mm PST Stage 1
Posted: Thu Apr 11, 2019 4:31 am
by Starry Jack
Just wanted to check in and say the continual stream of advice here is making my images better. This is a stack of 43 using Autostakkert with some slight curves in GIMP. I did the stacking and the curves remotely using my tiny phone so they ended up pretty dark, but I actually like it in this case!
- 0002_g4_ap2867_conv gimp1v.png (2.51 MiB) Viewed 3094 times
Re: Getting better...Sunspot with 152mm PST Stage 1
Posted: Thu Apr 11, 2019 2:07 pm
by Starry Jack
And as always, comments for improvement welcomed. For instance, I still shot in color (not having good time with mono yet) and I did not do any sharpening or wavelets (Registax is flaky for me as many of my tools minimize and never come back to where I can view them in an expanded state).
Jack
Posted: Thu Apr 11, 2019 4:39 pm
by marktownley
That's pretty impressive. Persevere with mono would be my advice.
Posted: Wed Apr 17, 2019 8:14 am
by Valery
Jack,
My advice to use about 67% of the present scale. You will not loose the reasolution, but will win in Signal/Noise and can use shorter exposures, will gain in the FOV size. And, of course, no coloration till your post processing is finished.
Posted: Wed Apr 17, 2019 1:00 pm
by Starry Jack
Thank you, Val. Can you explain more about your suggestion to use 67 percent of the current scale? I am not sure what that means in execution. Is that telling the camera to capture a smaller region of interest? Or telling my stacker to use a region of interest?
Jack
