I am mounting a front 100mm aperture ERF on a 110mm aperture F9.4 telescope 1035mm Focal Length telescope, stopped to about F10 by moved forward collimator lens, which is a PST Mod.
How much do I need to tilt the ERF? Does the reflection need to be outside the focal plane image or some point in front, the position of the PST collimator lens or its original position where the holder is acting as a baffle?
Andrew.
Tilt needed on a front ERF?
- Has thanked: 3295 times
- Been thanked: 1887 times
- Has thanked: 173 times
- Been thanked: 615 times
Re: Tilt needed on a front ERF?
I mount the D-ERF with a 1 -1.5mm tilt.
That's usually enough to prevent issues.....
- Bob Yoesle
- Has thanked: 540 times
- Been thanked: 807 times
I recall the general parameter for both external and internal filter tilts is about 2 degrees.
