Tilt needed on a front ERF?
AndiesHandyHandies
Has thanked: 3317 times
Been thanked: 1907 times
Post by AndiesHandyHandies »
I am mounting a front 100mm aperture ERF on a 110mm aperture F9.4 telescope 1035mm Focal Length telescope, stopped to about F10 by moved forward collimator lens, which is a PST Mod.
How much do I need to tilt the ERF? Does the reflection need to be outside the focal plane image or some point in front, the position of the PST collimator lens or its original position where the holder is acting as a baffle?
Andrew.
Has thanked: 174 times
Been thanked: 619 times
Re: Tilt needed on a front ERF?
Post by Merlin66 »
I mount the D-ERF with a 1 -1.5mm tilt.
That's usually enough to prevent issues.....
Has thanked: 541 times
Been thanked: 811 times
Post by Bob Yoesle »
I recall the general parameter for both external and internal filter tilts is about 2 degrees.
