10 improvements to my solar telescope set up
danpro1
Oh, I get it now!
Oh, I get it now!
Post by danpro1 » Wed Jul 03, 2019 1:41 pm
Hi guys,
This is a video on small improvements that I have made to my solar telescope setup. It includes simple motorized focussing, more cameras, better white light filter setup, etc. My apologies if the sound level is low; it tested fine before I started to record :-(
Daniel
https://youtu.be/illIrqzWu84
robert
Re: 10 improvements to my solar telescope set up
Post by robert » Wed Jul 03, 2019 6:27 pm
Really nice setup, beautifully done. Thanks for sharing. Got some ideas from it I think.
Robert
2020 images https://tinyurl.com/v6muwvm
Post by marktownley » Wed Jul 03, 2019 7:09 pm
cool setup and some top tips
Post by Montana » Thu Jul 04, 2019 2:11 pm
:movie Nice video Daniel
DanielBrousseau
Post by DanielBrousseau » Thu Jul 04, 2019 4:23 pm
Encore merci de ta générosité Daniel, tu me donnes de bonnes idées !!!!!
Skywatcher 120ED, Celestron 150mm f/8 achro, Quark Chromosphere, ASI174 monochrome, ASI290 mono
Sherbrooke, Québec, Canada
Martin_S
Post by Martin_S » Thu Jul 04, 2019 9:43 pm
Great set up Daniel thank's for sharing it with us.
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED100 , Homemade solar wedge, IR cut filter, ND3.0 filter, #58 green filter
Mounts
Skywatcher HEQ5 Pro Mount ,Skywatcher AZGTi Mount.
PDB
Post by PDB » Fri Jul 05, 2019 8:02 am
That's a great video and setup Daniel.
Specially liked:
- the 90° gearboxes for the motor focus. Never would have come with that idea.
- that you can handle 3 cameras in parallel. Your laptop / USB is very good
Can you also record in parallel or does that slow framerates?
Maybe an 11 th improvement. Get or build an SSSM. (And with the plugin I made for FC you should be able to control all 3 telescopes at the same time from 1 device)
Paul
Post by Carbon60 » Sat Jul 06, 2019 7:06 pm
Nicely done, Daniel.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
