Double stack with a Quark
hopskipson
Has thanked: 413 times
Been thanked: 197 times
Post by hopskipson »
I’m thinking of taking advantage of the Lunt sale and getting a 60 mm single stacked scope. Is it possible to double stack it with a Quark? If so will I need a blocking filter or is the Quarks bf okay?
Has thanked: 20819 times
Been thanked: 10489 times
Re: Double stack with a Quark
Yes. It is possible to DS with a Quark, the Quarks BF is ok.
hopskipson
Thanks for the reply Mark!
hopskipson
I finally got the Lunt 60 pressure tuned 1200 today. As a follow up, which blocking filter has better transmission? Will I also need an IRUV cut before the Quark? Also picked up a US made pst and AOK Swiss adapters. I’m thinking of using it for double stacking the Lunt with this also. Does anyone have any experience with either one of these configurations? Thanks again!
