12" White light Newtonian
AndiesHandyHandies
Has thanked: 116 times
Been thanked: 66 times
Post by AndiesHandyHandies » Thu Oct 24, 2019 8:09 am
I now can use some bits for a 12" dobsonian.
I lent the mirror to someone and they cleaned it without asking and took half the aluminium off!
'Home' aluminised at my first club and some pre-cleaning artefact in the coating it looked like.
So might as well take it all off.
Whats the best narrow band filter (s) to use?
Rod points out he used a 10" Newtonian for solar projection for hours with no issues.
Andrew
MalVeauX
Has thanked: 54 times
Been thanked: 70 times
Re: 12" White light Newtonian
Post by MalVeauX » Sat Oct 26, 2019 2:06 am
Heya,
Well, use a 656nm (Astronomik HA 12nm) filter for poor seeing.
Use a 395nm or 430nm (Andover or Edmund Optics) for higher angular resolution with very good seeing.
AndiesHandyHandies
Post by AndiesHandyHandies » Sat Oct 26, 2019 7:45 am
Thanks.
bart1805
Post by bart1805 » Sat Oct 26, 2019 8:20 am
Don't forget to de-aluminise the secondary mirror!
Has thanked: 1287 times
Been thanked: 534 times
Post by marktownley » Sat Oct 26, 2019 10:58 am
Depends how much light you want coming through 😉
bart1805
Post by bart1805 » Sat Oct 26, 2019 11:23 am
Yep, you are absolutely right!
allhoest
Been thanked: 4 times
Post by allhoest » Sun Dec 01, 2019 4:40 pm
"Don't forget to de-aluminise the secondary mirror!"
If you do so, you will have a very strong filtering.
Maybe you want it that way, but keep in mind that you will have to collimate it!
christian viladrich
Been thanked: 48 times
Post by christian viladrich » Fri Dec 20, 2019 10:59 am
As said by Alexandre, just keep the primary uncoated and the secondary coated.
Regarding filters, it all depends on the seeing conditions at your place. A 300 mm is a bit of a large telescope for solar image.
The range of usual filters are :
- deep-sky Ha, when seeing is bad,
- 540 nm, when seeing is good,
- deep-sky OIII, when seeing is pretty good,
- 430 nm, when seeing is excellent,
- 396 nm, when seeing is perfect.
http://www.astroplanetes.com/
