I use a 1.6x, 2x and 2.6x TS GPCs. Only one at a time.
These are 1.25" diameter, compact, fairly inexpensive and meant for binoviewers.
- P1440040 rsz 600 gpcs txt.jpg (73.77 KiB) Viewed 540 times
Overall variation of focus point, compared to no GPC at all, is less than 18mm or 3/4".
My 2" SVBony helical focuser could easily manage these changes.
But its considerable length was a nuisance when used without a GPC.
After suffering flexure and then failure with the short throw helical I played safe and went to sturdy 2" fittings.
Only the last two fittings at the camera were T2 and 1.25". The BF sits inside the last 2" adapter.
The first image is the setup I have been using for quite a while now:
- P1440191 rsz.JPG (123.82 KiB) Viewed 540 times
The second image shows my latest attempt with the now overburdened, helical focuser at the backplate:
- P1440209 rsz txt.jpg (180.21 KiB) Viewed 540 times
The helical focuser is soon to be replaced with an FTF2535HD.
The FTF is [probably] slightly shorter but not sure yet.
- P1440266 rsz.JPG (213.6 KiB) Viewed 540 times
I have turned a new backplate for the FTF but won't have all the necessary adapters until Friday.
That is the 2" end cap sitting inside the FTF base plate with levelling screws.
Normally the 2" adapter would screw into the top of the drawtube.
The large adapter, nearby, was supposed to support the protective UV/IR filters on forward extensions.
A work in progress because the FTF2535 has no internal thread on the drawtube.
- P1440236 rsz 600 ftf.JPG (78.95 KiB) Viewed 540 times
