I'd installed a Losmandy top rail on my HaT a few years ago now so that I can piggy back other scopes / SSM etc. However have always thought that while the handle on celestron SCTs were in the right place for carrying a scope around, it was in the wrong place for lifting it onto the mount, and I never feel comfortable once i'm hoisting the OTA above waist height. I'd looked around a few astronomy retailers for a 'handle' and was shocked at the price. A handle is still a handle whether it is for a telescope or anything else for that matter, as long as the load rating is fine all is good. Having a clear out at work and noticed a wheeled trolley unit that had collapsed and was out for the skip had a handle to move it around. Seeing it was only bolted on I rescued it with the intention of installing on said top rail. It works well, and still gives me enough space at the front of the rail for mounting options. Is in just the right spot to hold when mounting the OTA. Mr Health and Safety is happy as is the CFO.
P1000647 by Mark Townley, on Flickr
AiryLab HaT Handle Mod
- Has thanked: 20442 times
- Been thanked: 10247 times
- Been thanked: 4340 times
Re: AiryLab HaT Handle Mod
Hi Mark...
Great to see your re-purposed handle installed...will be a major benefit to mount/dismount the OTA
Did you bolt it directly to the top rail (hard to tell from the pic)? The commercial handles typically have the removable brackets that mate to the dovetail which is what adds so much to their price tag.
Thanks Brian.
Yes, the handle is bolted to the top rail. I had to undo the top rail from the mounting blocks, blind fix the handle with an allen bolt and nut to the top rail and then fix it all back down on the mounting blocks. I was also pleased that it all still fits in the hard carry case I have for it.
Next thing will be to replace the bottom orange rail with on that matches the top rail, but that's just me being vain about matching cosmetics and a job for the future
- Has thanked: 8418 times
- Been thanked: 8163 times
Looks great, Mark. A neat, practical, solution.
Thanks Stu!
- KMH
- Has thanked: 641 times
- Been thanked: 725 times
I have to admit I coughed up the $$$ for the ADM handle for my C-11, and the possibility of a hardware store alternative didn't even occur to me. Oh well. It does make a huge difference though - much easier and more secure to carry around.
- Has thanked: 17572 times
- Been thanked: 16694 times
Nice!
There is a handle available at Astronomics for my AT72EDII refractor. I have thought about purchasing one. If I found one elsewhere that would fit it I would certainly jump on it as you have.
- Been thanked: 8791 times
That is exactly what I did as soon as I bought the C11, the handle was in completely the wrong place!!! who designs these telescopes?
The handle is essential!!
Getting ready for Spring by Alexandra Hart, on Flickr
Alexandra...
My thinking is that the 'stock' handle is intended for being able to grab the scope and point it.. It can also to give you a hand hold if you release the axis locks and if the scope isn't balanced just tight you can keep it from swinging and causing damage.
As for a carry handle, it is not overly practical .
