Great Attractor: 90mm aperture: Lunt LS50THa modification to 90mm aperture: solar chatforum article: viewtopic.php?f=9&t=19238
Dear Solar Chatforum/Great Attractor,
As of 22nd March 2021, from sunny London.
Hi, I am hoping to get some help with regarding building a modified scope like Great Attractor's Lunt LS50Tha modification to 90 mm aperture.
I had a little difficulty understanding all the technical details, so I summarise what I understand. Please correct me on any mistakes !
1) The reason for this modification is to get increased resolution from a 90mm optical lens compared to a 50mm lens, increased contrast and optical performance for imaging of sun surface and proms.
2) Components of this modified scope are (from front to back):
a) The 90 mm Baader D-ERF
b) the donor OTA body of Celestron SkyScout Scope 90 (http://www.teleskop-express.de/shop/pro ... Scout.html) – f/7.33. Basically the metal tube and the 90mm objective lens
c) Donor OTA adaptor (not sure of where this is, or dimensions)
d) extension tube of 49mm length (M68)
e) Coronado BF15 converted to straight-through configuration - for surface imaging of sun (lunt BF600 for imaging of proms can be used)
f) Barlow 1.6x (to obtain better sweet spot focusing)
f) ? Borg helical focuser
g) Camera - PGR Chameleon 3 mono (ICX445)
h) Mount : HEQ5-Pro
i) Laptop+ software
Basic cost (excluding camera and mounts and computer hardware+software): at current prices:
Original Lunt LS50THa: £1329 (https://www.firstlightoptics.com/lunt-s ... scope.html)
Baader front D-ERF 90mm £345 (https://www.widescreen-centre.co.uk/baa ... lters.html)
Celestron Skyscout 90mm OTA = approx ? £150
Coronado BF15 = unable to find this, ? on widescreen centre, a B1200 filter for 1.25inch or 2 inch diagonals is £924, for B1800 it is £1424 (https://www.widescreen-centre.co.uk/blo ... cuser.html)
Borg helical focuser ? 1.25 inch focuser from Rothervalleyoptics = £59 (https://www.rothervalleyoptics.co.uk/zw ... r-125.html)
Other costs: Camera :about £400 to £1000 https://www.edmundoptics.eu/f/point-gre ... ras/15023/
HEQ5Pro: about £1000 (https://www.rothervalleyoptics.co.uk/sk ... ripod.html)
Total for: Lunt LS50THa+camera+mount= £2829 (assume £500 for camera) - not including computer and other small accessories
Total for modified scope= £2829 + another £ 1478
Approximate cost of 90mm modified scope = £4307
Is that about right ?
I did not properly understand all the parts from around the OTA focuser onwards. I assume it is possible given the right expertise and purchase of all the right parts, as the Great Attractor's modified scope gives incredible images, probably among the best high resolution pictures of the sun's surface I have seen on this site or anywhere in fact. Maybe Great Attractor could clarify my uncertainty over the components from the back of the 90mm scope (a listing of the components all that is necessary) in their sequence. Am I about correct about the costs, or is there a less expensive way to go ? second hand or a special solar telescope business I don't know about.
Thanks.
Magnus
London
Questions about 90mm mod to Lunt LS50THa by Great Attractor
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- GreatAttractor
- Has thanked: 749 times
- Been thanked: 757 times
Re: Questions about 90mm mod to Lunt LS50THa by Great Attractor
Hi Magnus,
The mod's purpose it to increase resolution; contrast is about the same (i.e., not too high when observing surface details visually, but the prominences are excellent. On camera, contrast is of no issue, one can always record with lower gamma and/or enhance contrast in post-processing.)
The prices seem right, though it was noticeably cheaper back in the day (I bought the D-ERF in 2013, the mount in 2014, the Lunt in 2015, and the BF15 I got cheaply from Solarchat's classifieds).
Maybe let's continue the technical discussion in the mod's thread.
I'm glad you like them, but objectively my scope cannot compete with others' 5", 6", 8", 11" and 14" setupsthe Great Attractor's modified scope gives incredible images, probably among the best high resolution pictures of the sun's surface I have seen on this site or anywhere in fact
