Hello everyone,
Just asking how everyone plans to shoot your eclipse photo.....
1. time lapse at a regular interval
2. video short segments for stacking at a regular interval
3.just photo segments
4. full disc ... or close-ups
I plan on using firecap and set up an auto run of a mix of 1 & 2 .. at full disc
Thanks for everyone's input
How is everyone planning photo sequence for Eclipse?
Lunt LS100THA
TEC 140
AP Mach1gto
Lunt b1800 H-Alpha
Lunt b1200 K-Line
ZWO 174mm & 1600mm
TEC 140
AP Mach1gto
Lunt b1800 H-Alpha
Lunt b1200 K-Line
ZWO 174mm & 1600mm
- The Sun?
- Has thanked: 20432 times
- Been thanked: 10243 times
Re: How is everyone planning photo sequence for Eclipse?
Randomly take pictures as I feel like it!
- The Sun?
- Been thanked: 6 times
Planning a photo sequence for an eclipse requires careful consideration of various factors to capture the event effectively. Here are some steps and tips for planning a photo sequence for an eclipse:
1. Research the eclipse: Find out the date, time, and location of the eclipse you want to photograph. This information will help you plan the logistics and understand the conditions under which you'll shoot.
2. Choose your equipment: Select the appropriate camera and lenses for the type of photos you want to shoot. A DSLR or mirrorless camera with interchangeable lenses is preferred for its versatility. A telephoto lens can help you capture close-up shots of the eclipse, while a wide-angle lens can capture the surrounding landscape and atmospheric changes.
3. Scout your location: Determine the ideal location to photograph the eclipse. Consider factors such as accessibility, unobstructed views, interesting foreground elements, and safety. It's also crucial to check the weather forecast for that location to ensure clear skies.
4. Plan your composition: Visualize the shots you want to capture during different eclipse stages. Think about incorporating foreground elements such as buildings, trees, or people to add context and depth to your images. Experiment with different compositions in advance to ensure you're ready when the eclipse occurs.
5. Consider safety measures: Never look directly at the sun without proper protection, as it can damage your eyes. If you're planning to photograph the eclipse, use certified solar filters or eclipse glasses to protect both your eyes and your camera equipment.
6. Use a tripod: To capture sharp images during the eclipse, utilize a sturdy tripod to keep your camera stable. This is particularly relevant during long exposures or telephoto lenses.
7. Test your settings: Familiarize yourself with the camera settings you'll use during the eclipse. Perform test shots in advance to find the appropriate exposure settings for different eclipse stages. Manual mode is often preferred to control exposure, aperture, and shutter speed.
8. Capture the progression: Start shooting before the eclipse reaches totality. This allows you to capture the different phases, from the partial eclipse to the maximum eclipse and then back to the partial phase. Take a series of shots at regular intervals to create a time-lapse or photo sequence showcasing the changing appearance of the sun and the surrounding environment.
9. Experiment with different techniques: Get creative and experiment with different techniques during the eclipse. You can try multiple exposures, HDR photography, silhouette shots, or even include people or landmarks in your composition for added interest.
10. Enjoy the experience: While it's essential to focus on capturing stunning photos, don't forget to immerse yourself in the eclipse experience. Take a moment to enjoy the natural phenomenon unfolding before you.
Safety should always be a priority when photographing an eclipse. Protect your eyes, follow the manufacturer's guidelines for your camera equipment, and ensure you're in a safe location throughout the event. Solar companies
[https://agnisolar.com/][/solar power system]
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hi Amit,
Very detailed and helpful outline.
I was wondering about tracker mounts as that would reduce the need to adjust your camera position as the sun moved across the sky. Any recommendations? And what are you taking. Then there are battery and power supply.
Should there be a special image exposure sequence for the seconds just before totality and emergence from totality, that is separate to the time before and after totality.
I have or others have posted links to detailed solar imaging info on other specialist eclipse sites.
