Ha HiRes from St Véran
Hello all, with Christian and some other, we are imaging from St Véran Observatory in the french Alps.
I'm using a HaT8 and HaT11 with a SS .3A.
The seeing is tremendous...
I have animation, but the bandwidth is scarce here, I'll post them when I'll get back home.
With the 8" :
With the 11" :
With the 8" :
With the 11" :
- Has thanked: 9319 times
- Been thanked: 6156 times
Re: Ha HiRes from St Véran
These are fantastic, Frederic ! What were the seeing numbers on the SSM when you imaged these ?
- Has thanked: 8558 times
- Been thanked: 8290 times
A beautiful place to observe and image the Sun. Fabulous images Frederic.
If the sun image wasn't absolutely steady, unmoving then this may be incorrect. If even a slightest movement were seen, that this can mean only one: the SSM is a bit too optimistically calibrated.
I personally do not believe that such a seeing is possible in a day time anywhere in the world. Especially for most of the time.
I just provided the JPL with several SSM, and we worked together on them for deliver the r0 as well, so I guess it's good enough for Caltech/NASA.
- Has thanked: 55 times
- Been thanked: 81 times
HI Frédéric,
fantastic - the solar surface and the site. Didn't know about St Véran when you recently mentioned it but I think it must be great to be at such a great place with great people and such a lot going on on the sun as these days with two new active regions just coming into view.
Best wishes to all of you and have a good time - great seeing be with you
Laura
Laura
It looks a bit like a solar imagers heaven. Happy hunting over there and please show us more of those beautiful pictures!
Bart.
Bart.
- Been thanked: 4427 times
Superb images Frederic
This fact of JPL/NASA interest does not necessary mean that the presesnt version of the SSM works absolutely correctly. In my understanding it returns _relative_ seeing values. No more. It can distinguish very good seeing from good seeing, good seeing from so so seeing, so so seeing from poor seeing and poor seeing from very poor seeing. But such a returns like 0,3" are not serious, as well as , say, 1,25". Such returns directly state that this SSM as sensitive as 0,01". Looks unrealistic.
Most solar seeing monitor, beside limb analysis, use the scintillation work of Beckers and Seykora. And especially SHABARs.
r0 are in line with expected results, and JPL guys are not shocked by those values.
We speak of instant seeing, not long exposure seeing.
By night time, planetary amateurs can reach very small details, well below the arc sec.
Same thing in solar imaging, look are Christian images.
Frederic,fjabet wrote: ↑Thu Aug 31, 2017 8:01 am Most solar seeing monitor, beside limb analysis, use the scintillation work of Beckers and Seykora. And especially SHABARs.
You are trying to change the subject of this discussion. JPL guys have nothing to do with your SSM. Shocked they are or not has nothing to do with the SSM unrealistic return values. They are: 1) incorrect 2) unrealistic. This what I state looking at SSM return values and know enough about atmospheric seeing.
I am well aware about what kind of resolution amateurs reach during night observing, I well aware about seeing statistic during day time.
I believe that the SSM showed 0,3" most of the time at that monting top. But I state that this value does not reflects the real seeing at that place that day(s).
There are NO places on the surface of the Earth where the day time seeing can be 0,3", especially most of the time!
You can easily prove that the 0,3" was there and was most of time by placing here or at other place (youtube etc) several movies through 11" HaT where we can see that the sun images are as steady as a whater in a glass. If not, then it will be better to calibrate the SSM correctly to achieve the point when it will returns more realistic seeing values. For now this SSM can be used as the seeing indicator like seeing is "very good", "good", "average", "poor" and "very poor".
BTW. I can show the images in H-a same good as Christian did and I know what were the seeing I took them at - not even close to 0,3". With 0,3" seeing most of the time(!) we do not need any lucky imaging technique. Absolutely.
Well, Christian did stacked only 7 images on his image actually.
Now believe what you want, this is not the subject of the thread.
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
Superb shots. I always think seeing is my limiting factor but it looks like a very tough place to live. I won't try to move there. Good to see the location, thanks.
Robert
Robert
1. This is not a real argument.
2. Now it is clear, that your SSM returns a way too optimistic seeing values and you can prove this statment wrong.
Again there are NO places on the Earth with daytime seeing on the level 0,3". If the SSM shows such a value (even below it) for a long time, this does mean only one: SSM is not correctly calibrated.
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
fantastic shots Frederic, awesome resolution, I have to join you guys one of these days
Pedro Re'
Thanks you guys !
@Valery : there is no calibration required in the SSM. Actually it's a pure transcription of Seykora and Beckers papers that was validated by the scientific community and the JPL has no issue with them, nor NASA that bought other units from one of my distributors.
Nor the professional observatory using it.
But maybe you know more.
Frederic,fjabet wrote: ↑Thu Aug 31, 2017 4:25 pm Thanks you guys !
I read that Seykora and Baker article. I am sure your SSM does work as there is a clear dependance between the seeing quality and SSM's return values.
Many scientists were mistaken even Einshtein. The same can be with Seykora and Baker.
Is there no way to adjust the SSM in such a way that it's return values will better correspond to the real seeing values? This must be a simple procedure electronically, but difficult on the practice.
At least I know the method of calibration. You can do this without additional equipment. At your home in a day of good seeing.
