Just time for a 'quick' solar image this evening after work. I say 'quick' because by the time I've lugged all of my gear around the house to my back garden it feels like much longer than the few minutes that it actually takes, going back and forth, taking a few pieces at a time. Anyhow, moments after getting set up on target and everything aligned and tuned the seeing conditions went to pot; almost literally it was like looking at the bottom of a swimming pool after only a few moments of relative calm. Thankfully I'd just managed to capture this image of a nice filaprom before the scope became useless under the conditions.
150mm/DS Lunt 35 with a 2.5x Powermate and acA1920-155um camera. I'm sure I should have re-orientated the image, but hey.
4000 images stacked using AS!3 and deconvoluted using Imppg. Further processing in PixInsight.
20180611_Filaprom by Stuart Green, on Flickr
and an inverted version....
20180611_Filaprom_Inverted by Stuart Green, on Flickr
The limb gives away the fact that the tuning was a little bit off.
Thanks for looking.
Ha Filaprom June 11th
- Has thanked: 8418 times
- Been thanked: 8162 times
- Has thanked: 9145 times
- Been thanked: 6025 times
Re: Ha Filaprom June 11th
That is a lovely prominence, Stu. I prefer the inverted version but they are both very nice. Lucky you had time to image on a work day.....
- Has thanked: 17672 times
- Been thanked: 8791 times
sounds like the Sun just started passing over the neighbours barbecue
Fantastic image, you can see how the plasma is like a thin veil and see through, what a delicate structure although it is probably the size of Earth.
- Been thanked: 1735 times
Hi, Stu
I always prefer a "right side up" orientation to prom images, just the way I look at life. The floating impression is enhanced this way.
Lou
Lou
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Great Ha HR prom shot there Stu, great resolution
Pedro Re'
Many thanks for your feedback, everyone.
Certainly seemed that way, Alexandra.....
- Been thanked: 4904 times
Stu:
Beautiful Filaprom image in both versions.
I also prefer the "right side up" orientation in prominence images.
- Has thanked: 20438 times
- Been thanked: 10245 times
That's a lovely shot Stu!
Many thanks, Eric & Mark.
