Outreach with firecapture/pst?
I'm using an asi178 along with a pst and firecapture. I really like the software... but I'm having a tough time getting the proms to "pop". Any advice with firecapture settings would be greatly appreciated.
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: Outreach with firecapture/pst?
Just turn up the exposure?
If I increase exposure time or gain the histogram quickly gets to 100% and it's blown out. I read that I should keep the histogram around 60-80%.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
No way you can get surface and proms in one exposure. For proms you need to turn up exposure, surface detail will be higly overexposed and your histograram way over 100%, but that is the only way to do it. Brightness level between proms and surface is too big.
You have to combine separate exposure in post processing to get both on the same picture.
Update: with the ASI178 in 16 bit mode in FireCapture it is actually possible to capture both surface and proms, but the proms will be very faint. In the stacked image (from AS!3) you can make them visible by playing with the gamma settings. (But then surface will get overexposed again)
- pedro
- Has thanked: 14 times
- Been thanked: 6578 times
I always take 3 separate sets of videos with different gamma settings.
Low gamma values for surface detail and high for proms.
You can also overexpose the disk to get more prom detail
Pedro Re'
- banjo
- Has thanked: 2090 times
- Been thanked: 2859 times
a Mr Colmic solution with photoshop to bring out the low levels
- Sans titre 3.jpg (70.17 KiB) Viewed 3867 times
- Sans titre 4.jpg (107.45 KiB) Viewed 3867 times
sorry for my English translators google
Thanks for sharing your settings
