Hi all,
An active area AR12717 on the sun, August 1, 2018. This is a dipole - an emergency flux area.
Telescope C8 203mm F/10 SCT equipped with the ARIES 214mm two bands dielectric energy rejection filter (DERF), PST etalon camera Basler 1920-155.
Pictures are in the core of the H-a line and in the red and blue wings of the H-a line. Note that in the red wing of Ha a photospheric granulation is perfectly visible, while in the blue wing it is not visible.
Seeing was average.
Thanks for looking.
New AR12717 August 01 2018 C8 telescope with 214mm DERF
- AR12717-Aug-01-2018-UT-05h-24m-H-a-core.jpg (293.15 KiB) Viewed 1657 times
- AR12717-Aug-01-2018-UT-05h-30m-H-a-BlueWing.jpg (291.24 KiB) Viewed 1657 times
- AR12717-Aug-01-2018-UT-05h-27m-H-a-RedWing.jpg (289.84 KiB) Viewed 1657 times
- Has thanked: 20783 times
- Been thanked: 10475 times
Re: New AR12717 August 01 2018 C8 telescope with 214mm DERF
These are excellent images, i like on the last one how you can see the granulation starting to poke through.
- Been thanked: 8906 times
These are tremendous Valery, I really enjoyed these
Thanks, Alexandra and Mark
I enjoy the difference in loop prominence appearance between blue and red wing as well as different appearance of the photospheric (RW) and lowest chromospheric (BW) "surfaces".
- Been thanked: 4425 times
Very impressive Valery...especially the granulation lurking in the background of the red wing image
Thanks, BrianMapleRidge wrote: ↑Sat Aug 04, 2018 12:22 am Very impressive Valery...especially the granulation lurking in the background of the red wing image
When I imaging in H-a I really hate all these lurking photospheric cells network.
- Has thanked: 1 time
- Been thanked: 2725 times
Very nice set of images Valery !
- Has thanked: 8556 times
- Been thanked: 8284 times
Excellent images, Valery. Interesting to see in detail the Ha wings.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Beautiful images, Valery.
The off-band views are very interesting. The enhanced (loop?) absorption in the blue wing seems to be consistent with the picture of prominence gas condensing out of the corona and streaming down to the surface. Do you have an idea of the wavelength offsets in your detuned images?
Cheers, Peter.
Cheers, Peter.
Thanks, Christian, Stu and Peter!
Peter, I don't know how much were the detuning in these cases, but my guess is +0,5 to +0,7A red and -0,6 to -0,7A blue.
