Still orbiting around the Sun....
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Today first clear and sunny day since October 20th. Of course the seeing is terrible as the atmospheric circulation changed from a humid and cloudy African anticyclone to a dry Russian cyclone together with an abrupt temperature fall. No high resolution possible however I did my best to capture a full calcium disc and AR12727, with poor results. This small group is formed by few spots but is very bright in H alpha and in calcium H also. There were also few prominences and filaments but due to the turbulence I decided to give up.
- 2018-11-17-1254-RB-Halpha-AR12727.jpg (21.24 KiB) Viewed 1256 times
- 2018-11-17-1224-RB-CaH-AR12727.jpg (61.74 KiB) Viewed 1256 times
- 2018-11-17-1214-RB-CaH-fulldisc.jpg (63.35 KiB) Viewed 1256 times
Re: Still orbiting around the Sun....
Nice session, Raf. This is in any case better than nothing (at most places in Europe).
Thanks for sharing.
Thanks for sharing.
- Has thanked: 9327 times
- Been thanked: 6163 times
Bellissimi risultati nonostante le povere condizioni atomosferiche ! Excellent results notwithstanding the poor atmospheric conditions, Raf !
Sorry, I had to practice my Italian otherwise I forget....
- Been thanked: 4434 times
Great to see you managed to get clear skies, and good captures despite the conditions
- Has thanked: 8559 times
- Been thanked: 8297 times
Tough conditions, Raf, but some Sun is better than none. Nice images.
- Has thanked: 20828 times
- Been thanked: 10502 times
Nice set of images Raf!
- krakatoa1883
Thanks to all for your comments, very kind
The group is still there, both the trailing and following spots are slightly larger than yesterday, look at it if you can.
- Been thanked: 4981 times
Raf:
In spite of seeing conditions, the session was very good.
- Been thanked: 8907 times
These are great! that spot group was small so you managed to get quite a hi res image of it, well done, nice work
