January 4th Sun
- Been thanked: 4340 times
January 4th Sun
Good day everyone...
I was fortunate to have another clear day on Friday (Jan 4th) and managed to get some time to image over the lunch hour. Seeing was typical for winter (poor, but not as bad as some days ) and most of the images were usable with the exception of the prom shots.
The sequence started with full disk Ha thorough the LS80T/LS75FHa/B1200Ha solar scope. These composites were made form separate disk and limb images with PGR Grasshopper Express camera (ICX674 chip), shown with a variety of styles:
I did not get any full disk WL or CaK images, but I was able to get images of AR2732 at prime focus and through a 3x barlow on the iStar 150mm, f8 scope using the ASI 174MM camera. The WL images were through a Lunt solar wedge/Baader Continuum filter (sorry, image brightness is too high) : The CaK images used a modified Lunt Solar Wedge/B1800CaK/Baader K-Line filter set: The remaining images were taken through the modded CR-150/DSII/B1800Ha scope with a 3x tele-extender in front of the ASI174MM camera. The four images below show the views as you tune the DSII pressure tuner form 0PSI to 20PSI, where the 0PSI gives a WL view and 15PSI seems to be closest to on band based on the contrast of the features: I cropped each of the full frame images to highlight AR2732 and laid them out in order in the pic below: To finish off, an animation was made form the four frames to show the changes as you proceed from 0 PSI (Continuum) to 7.5 PSI (Red Wing) through to 20 PSI (blue wing)...click to open: Overall it was a good day at the scope
- Has thanked: 9144 times
- Been thanked: 6025 times
Re: January 4th Sun
A very nice set of images, Brian. It looks like you have a continued luck with the weather in 2019... I am jealous
Re: January 4th Sun
Thanks for your feedback Franco
We are only a few days into the new year, so I'm not sure if this is enough clear weather to set the trend for the next 360 days
- Been thanked: 4904 times
Re: January 4th Sun
Brian:
Very nice session in spite of bad seeing.
I have the same problem at my home observatory, plus high contamination.
Re: January 4th Sun
Many thanks Eric...the feedback is always appreciated !!!
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Re: January 4th Sun
These are great Brian. Glad the weather has been obliging for you over the holiday period. I like the off band sequence.
Re: January 4th Sun
Maurits and Mark...
Thanks for your comments and feedback guys, always appreciated
I like to adjust the tuning and see what differences appear, but the Lunt makes the change very quick with the pressure tuner. Teh Daystar filters can be tuned, but takes more time than I have patience to stabilize the etalon after changing the set point
Re: January 4th Sun
Brian,
Great set of images and quite informative. I can see the rapid tuning via pressure is a big plus over the heated etalons I use. Twenty minutes to bring the Solar Spectrum up to temperature and about ten for the Quark.
Phil
Phil
Re: January 4th Sun
Hi Brian,
Nice images. Especially the sequence of different CWL positions. Thanks for sharing.
Re: January 4th Sun
Hi Phil,
I always use tilt tuning etalon for quick overview of active areas with dark surges and streams. The same with large eruptive prominences. This shows how much the difference I can expect from the CWL scan.
- Has thanked: 17666 times
- Been thanked: 8787 times
Re: January 4th Sun
Beautiful set as always Brian. I enjoyed the tuning images/animation again what happened with the pattern noise in the CaK shot though? I have not seen this before.
Re: January 4th Sun
Thanks Alexandra, I figured you would like the tuning set
I can't explain the horizontal lines in the one CaK shot, but not the first I've seen them (thankfully only show up a limited number of times before). I will have to keep better track of the settings/conditions in the future.
- pedro
- Has thanked: 14 times
- Been thanked: 6575 times
Re: January 4th Sun
Thanks Brian, great post and discussion, off band imaging can be a plus
Pedro Re'
Re: January 4th Sun
Pedro and Pepe...
Thanks for your comments and feedback on this session, it is always appreciated!!!
Re: January 4th Sun
A fine set ! Brian
The interlaced artifact consistently happens to me, too, whenever I push fast exposures (<1ms)
-Mike
- Has thanked: 8415 times
- Been thanked: 8161 times
Re: January 4th Sun
You've been busy, Brian..... Nice set of images. The tuning sequence looks great.
Re: January 4th Sun
Mike and Stu...
Thanks fro your comments
Mike, you raised an interesting point about the horizontal bands...I pretty much had to have the exposure as low as it would go to take the image. Will have to check this more closely next day its clear.
