AR12738 at High Res through 150mm refractor and QUARK Chromosphere.
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi all,
April 11 morning was reither cloudy and foggy. However in two hours the sky cleared.
The seeing was average but with some improvements.So, I took my computer and Quark and
quickly set up the telescope.
Here is the best shot of the AR12738 I was able to take.
The telescope is SkyWatcher 150/750 equipped with the ARIES full aperture DERF, Quark Chromosphere and Basler ASA 1920-155 camera. A 2x TV PM barlow has been used to get F/43 at the etalon (remember that Quark has it's own build-in 4,3x telecentric barlow). F/43 at the etalon helps to keep etalon's bandwidth maximally narrow and so, best possible image contrast.
Thanks for looking.
JohnW
Been thanked: 1624 times
Re: AR12738 at High Res through 150mm refractor and QUARK Chromosphere.
Post by JohnW »
Good detail Valery. I saw this spot yesterday but its good to see it up close. Thanks, John W.
Has thanked: 8523 times
Been thanked: 8253 times
Nice one, Valery. Lots of fine detail.
How many Quarks did you get through before you got a good one?
Has thanked: 20743 times
Been thanked: 10439 times
This is an excellent capture Valery
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
Hi Valery,
That is a very nice image, despite the weather. I am also keen to try using a Quark Chromosphere on my Celestron 150mm Omni XLT fitted with an ARIES D-ERF. Do you use a 2" 2X TV barlow immediately at the output of the telescope followed by the Quark Chromosphere? Any other adapter/spacers required in between? Can you show a side-view picture of the telescope with the Quark and Basler camera?
Thanks.
Alfred
Has thanked: 1179 times
Been thanked: 1369 times
Post by MalVeauX »
Lovely capture Valery!
Post by Valery »
yltansg wrote: Fri Apr 12, 2019 5:47 am Do you use a 2" 2X TV barlow immediately at the output of the telescope followed by the Quark Chromosphere? Any other adapter/spacers required in between?
Yes, correct. And no optics in between.
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
That is an excellent image Valery...well done :bow
Post by Valery »
Carbon60 wrote: Fri Apr 12, 2019 5:28 am Nice one, Valery. Lots of fine detail.
It's uniformity is far from perfect. Visually the non-uniformity is relatively easily seen, especially when moving accross the sun disk.
It is very narrow, but not really uniform,
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Excellent Valery.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Post by Valery »
Thanks, Maurits.
Has thanked: 17925 times
Been thanked: 8892 times
That's a cracker Valery :bow :hamster:
