May 10th Spots
Astrophil
Been thanked: 581 times
May 10th Spots
Post by Astrophil »
Hi All,
A nice day for solar imaging, only a few clouds and a light breeze. The Quantum Six was the scope of choice today. First off are portraits of the active regions then a group shot. Finally, not to the waste time while the etalon heated up, AR12741 without it's chromosphere cover.
Phil
may 10 mosaic small.jpg (432.56 KiB) Viewed 1773 times
David_The_Bears_Fan
Has thanked: 423 times
Been thanked: 167 times
Re: May 10th Spots
Post by David_The_Bears_Fan »
Great shots.
David
Kit: Skywatcher Evostar 120 on Celestron CG-4 / Bresser AR102xs / Lunt B1200 Ca-K Module / Lacerta Herschel Wedge / Daystar Combo Quark / ZWO ASI178MM & 120MC-S / QHY5-II Mono
Davidm
Has thanked: 1 time
Been thanked: 289 times
Re: May 10th Spots
Post by Davidm »
Great detail and processing Phil!
Lunt LS152T (DSII and CaK module), Coronado Helios 1, Grasshopper 3 2/3" CCD
Has thanked: 1 time
Been thanked: 2725 times
Re: May 10th Spots
Post by christian viladrich »
Beautifull images and processing !
Has thanked: 1192 times
Been thanked: 1387 times
Re: May 10th Spots
Post by MalVeauX »
Fantastic capture Phil!
Has thanked: 9327 times
Been thanked: 6163 times
Re: May 10th Spots
Post by ffellah »
These are INCREDIBLE, Phil ! Perfect conditions, capture and processing...and great gear
Astrophil
Re: May 10th Spots
Post by Astrophil »
Thanks for the nice comments.
Oops, I mislabeled the images. They were taken with a Quantum Six telescope not an Questar. There is no Questar 6.
Phil
Has thanked: 17974 times
Been thanked: 8907 times
Re: May 10th Spots
Absolutely superb in every way, very sharp and crisp and yet beautifully smooth :bow :bow
Astrophil
Re: May 10th Spots
Post by Astrophil »
Thank you Alexandra, I have been trying to follow your suggestions. Now if I could narrow the bandwidth of the filter they would be better.
Phil
Christopher
Has thanked: 33 times
Been thanked: 34 times
Re: May 10th Spots
Post by Christopher »
I love that scope Phil! Beautiful work.
Christopher
MAURITS
Has thanked: 2464 times
Been thanked: 4881 times
Re: May 10th Spots
Post by MAURITS »
A very good and detailed session Phil.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: May 10th Spots
Post by p_zetner »
An exceptional set of images!
Peter
Has thanked: 64 times
Been thanked: 4434 times
Re: May 10th Spots
Post by MapleRidge »
Lovely images Phil...well done :bow
Has thanked: 20834 times
Been thanked: 10502 times
Re: May 10th Spots
Top shots! Lots of detail there.
