Anybody want to share their unprocessed source AVIs
Starry Jack
Has thanked: 141 times
Been thanked: 240 times
Post by Starry Jack »
I am trying to practice my processing skills. Does anybody have any source files they would like to share with before and after processing compares?
Best,
Jack
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Has thanked: 17925 times
Been thanked: 8891 times
Re: Anybody want to share their unprocessed source AVIs
Yes, but they tend to be huge so they can't be posted here, your e-mail wouldn't be large enough and WeTransfer only has a 2GB limit. This is why we don't tend to share source avi / ser files. If you have a solution then please share. My files around 6GB in size ;)
Starry Jack
Thank you, Alexandra! If you care to I have created a DropBox folder here: https://www.dropbox.com/sh/9ngoffizliij ... 8r97a?dl=0.
We can use this going forward to post some files if our Mods would like. Since I am posting the link in this forum it takes away security but that could be up to the donor if they worried.
I can also create a private folder and share the URL via PM only with interested parties.
Best,
Jack
Aeries D-ERF
12nm Filter
Bruce G
Has thanked: 128 times
Been thanked: 121 times
Post by Bruce G »
We used Dropbox successfully at my work for sharing huge ultrasonic data files with a collaborator. The trick is that someone needs to have a business account to handle the larger file sizes. But it sounds as though Jack has that part handled.
Starry Jack
Bruce brings up a good point. I can accept 50 GB files but I only have 38 GB free. So...l will still gladly accept donations up to about 20 GB total of space. My files are typically under a GB.
Jack
Aeries D-ERF
12nm Filter
Has thanked: 20741 times
Been thanked: 10439 times
Starry Jack wrote: Tue Jun 11, 2019 2:53 pm We can use this going forward to post some files if our Mods would like.
Yes, i'm fine with it.
250 frames with my 9Mp camera generates about 4Gb per image capture. I don't save them once processed as I run out of hard disk space quickly :D
Starry Jack
Thanks, Mark!
The donation door is open...small but effective is what we are looking for with a ‘final result’ link or image. A link or a note of some kind with your processing workflow would be lovely.
Jack
Aeries D-ERF
12nm Filter
Can I ask, how do you upload a file to this folder, I can only find an download button?
Starry Jack
Oops. Let me check.
Aeries D-ERF
12nm Filter
Starry Jack
Here is the official UPLOAD A PRACTICE FILE link: https://www.dropbox.com/request/tbomXBQiI27dTRqKA28y
Looks like there may be a 2 gig limit per file, but I know there are lots of files out there which meet that limit people could use to practice on. I'll load some myself, but my "befores" and "afters" are rarely as impressive as others in the forum.
Suggestions:
1) Post the raw video and name it with your name and any other important info
2) Post the "final result" image with the same name
3) Post a TXT, PDF, YouTube Link, URL etc. with your acquisition and processing workflow also using the same name
Hope this works and hope it helps the community at large.
Aeries D-ERF
12nm Filter
Starry Jack
UPDATED INSTRUCTIONS
(Added steps 4, 5)
Here is the UPLOAD A PRACTICE FILE link: https://www.dropbox.com/request/tbomXBQiI27dTRqKA28y
Suggestions:
4) Once you upload a file I will be notified and I will make the file viewable
5) Once I make the file viewable you can access all the files using this link: https://www.dropbox.com/sh/9ngoffizliij ... 8r97a?dl=0
Starry Jack
Aeries D-ERF
12nm Filter
Thanks Jack, I won't be home from work until bedtime tonight so I will have to look after work tomorrow or the weekend. All my files are 4.6GB so I will have to search through my archives to see if I have any smaller.
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Maybe this can be done via Dropbox or something. I thought .SER files are better as its 16 bit.
AVI files are only 8 bit.
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Radon86
Post by Radon86 »
Have you worked out the maximum size of files you can accept via dropbox?
Maybe you can send an empty Memory usb stick with a SAE and postage to a trusted forum member?
I still think you can practice with simple things like Lunar imaging files, so the Sun can be done later after you are more familiar with the programs...
Magnus
Starry Jack
I'm testing fe sizes in DropBox as we speak. I will report back soon.
Aeries D-ERF
12nm Filter
Starry Jack
I just uploaded a 7.5 GB file! Go ahead and try some of your uploads. Let's keep the file sizes smaller than that if possible so I can host at least 4 practice files. I suggest AVI only because of file size and universal tool acceptance. I also suggest solar ratherthan lunar because the purpose is to train folks on how close they can get to those awesome solar images that we know successfully post processed into a glorious image of the sun. In concept this excercise is like an artist copying a Rembrandt for practice and learn how close they can get to The Master.
Aeries D-ERF
12nm Filter
Starry Jack
Alexandra,
Thank you for submitting your practice video...it was lovely! I'd love to know what your equipment is. It is a clean video. I took a shot at post-processing and ended up with this:
Alexandra Hart - 021016_092304_lapl4_ap1849 AS3 to REG Wave to GIMP v1.jpg (133.58 KiB) Viewed 3566 times
The exercise was great fun for me and educational. I'd love to see YOUR version of the final product to see how close I came to the Rembrandt.
Best,
Jack
Aeries D-ERF
12nm Filter
Hello Jack,
Last night I managed to find one in the archive from 2nd October 2016 which was AVI and only 350MB in size. Good job as it took an hour to upload, I can't imagine how long it would take to do 5GB :shock: I am also not sure if we have a upload restriction each month, I know that we have only just gone on to unlimited download. I didn't have the time last night to fill in all the details, I dumped and ran :)
It was a Solarscope DSF100 and Grasshopper 3 camera. By the looks of the title in Flickr it was with a 2x Barlow.
Here is my Flickr image but I am not sure it is actually the same video file as it lacks the surge prom.
ImageProminence close up by Alexandra Hart, on Flickr
It is not the best, I am sure someone could do better :)
Starry Jack
Alexandra, thanks again. Hope the trials and tribulations were not to much! I really appreciate the contribution.
Aeries D-ERF
12nm Filter
Radon86
Post by Radon86 »
Hello Jack,
I downloaded your 7 GB files of high res area of sunspot in H-alpha I think, Thanks very much ! Those files are amazing. Have you used ImPPG yet? With some care, you could get really fine images with those equipment and that 7 GB file!!
I am new to solar , have only dipped into solar with a Quark chromosphere filter and a small 70mm refractor. I think my video files are ok. I am afraid to use the Autostakkert ! 3. I need to practice on something simple.
Thanks Alexandra for your small video file about 340 Mb. I have followed your work and your solar blog on solarnutcase. Thats tremendous work and skill, not to mention dedication and persistence on all things solar. Many congratulations on your awards on Insight Astronomy Photography competition. I saw your work in Greenwich, wow!!
I have got small progress using PIPP, AS!3 on a small moon image on an ultrawide shot of the cresent moon, so I expect quite good results. I thinks its basically knowing the software and whats been done.
I will hopefully show my work and ask for your help late this year...!
Thanks for all your time and sharing files.
Magnus
Starry Jack
Thank you, Magnus. I am eager for someone to process my file with bett3r skills than I have. I am also going to reprocess it myself with new skills I have learned.
I have dabbled in IMPPG but have not had great success, but that is not a knock on the tool, only my use of it. I am practicing using wavers in Registax and High Bandpass sharpening with soft light layers in Gimp.
Please share your results.
Aeries D-ERF
12nm Filter
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
Hi Jack,
I'll upload some AVIs overnight. Of course I don't store full material from each time lapse session (100-200 GB), but I keep 1-2 best videos for future experiments.
UPDATE: already uploaded, have fun.
My software:
My images
Starry Jack
Thank you for the contribution! So I did something foolish and clicked on your link to your animations. I WAS BLOWN AWAY. Those are simply inspiring views of Creation. Wow.
Because I am greedy (not really) if you have a post processed version of those files and steps well take those as well, but again, THANK YOU for these practice files. I hope they help many folks.
Jack
Aeries D-ERF
12nm Filter
Starry Jack
With the new skills I'm gaining I have reprocessed my 7GB file...this time with great success with IMPPG.
Workflow:
1) AS3
2) IMPPG
3) GIMP (Highlights down, Shadows WAY up, Levels, Curves)
New Image is:
0010_lapl4_ap13148 AS3 to IMPPG no REG yes GIMP.jpg (636.45 KiB) Viewed 3442 times
Aeries D-ERF
12nm Filter
Hi Jack, any chance you can change the last image for a compressed jpeg or png file, original is over 18Mb and takes an age to load. Thanks.
GreatAttractor
Starry Jack wrote: Sat Jun 22, 2019 1:54 pm Because I am greedy (not really) if you have a post processed version of those files and steps well take those as well,
Done - uploaded raw stacks, processed images and ImPPG settings files for each.
My approach:
My software:
My images
Starry Jack
My bad! I've removed the fat file. Just left the skinny one. 👍
Aeries D-ERF
12nm Filter
Starry Jack
Mark,
Sorry for the big file. I have removed it. Great suggestion.
Aeries D-ERF
12nm Filter
Starry Jack
Filip,
You are so generous! Thank you for the new files and settings. My skills and confidence are increasing because of the exercises and I hope others will enjoy as well.
Jack
Aeries D-ERF
12nm Filter
Starry Jack
Alexandra,
Again thank you for the files. I'm experimenting with those Inverse curves which give that 3D look. Here is yours, a bit over processed, but gotta keep learning.
I'll work on Filip's more as well. :)
Alexandra Hart - Processed by Jack Swaton as a TEST 021016_092304 AS3 to IMPPG with Inv 1 v1.png
Alexandra Hart - Processed by Jack Swaton as a TEST 021016_092304 AS3 to IMPPG with Inv 1 v1.png (2.96 MiB) Viewed 1252 times
Aeries D-ERF
12nm Filter
Starry Jack
And a quickie with Filip's. Trying to tame the ImPPG Curves is fun...advice welcomed.
Filip Szczerek - example3_stack Processed by Jack Swaton as a TEST v14.png (1010.66 KiB) Viewed 1252 times
Aeries D-ERF
12nm Filter
Can I make a suggestion Jack, check the 'cropped' box in AS3, it will get away with those image edge artefacts.
Starry Jack
Thank you, Mark. I will take every suggestion.
Aeries D-ERF
12nm Filter
