SHS at stellafane VT 2019
highfnum
Has thanked: 57 times
Been thanked: 1193 times
Post by highfnum »
its been improved
image as good as filter
only negative is narrow field view
Note any sun images taken by hand hold S8 do not show quality of image
but I posted them anyway
front end 18 foot lens assembly
highfnum
Re: SHS at stellafane VT 2019
Post by highfnum »
display of original speculum metal gratings and display cabin
highfnum
Post by highfnum »
old style power supply
highfnum
Post by highfnum »
collimator and spectrum in action
highfnum
Post by highfnum »
ok now for images (no justice)
I was able to see "peach" on surface and proms
but S8 camera could see flicker that human eye can not see refresh rate was 45 per second
but here they are anyway
I going to ask those guys if I can bring a better camera and mount to get better quality images
highfnum
Post by highfnum »
I tried a video
does give size portions
https://www.youtube.com/watch?v=HO_0Lbt2FkM
Has thanked: 174 times
Been thanked: 618 times
John,
Very impressive!
Good to see that the SHS is still recognised as a unique instrument and that it is still capable of producing great views of the Sun.
Has thanked: 20740 times
Been thanked: 10439 times
Interesting kit!
Has thanked: 17925 times
Been thanked: 8891 times
Wow!! I loved the video. That is an amazing instrument :hamster:
Has thanked: 8523 times
Been thanked: 8253 times
It’s always so very interesting to see these types of historical scientific apparatus, especially in action.
Thanks for sharing.
highfnum
Post by highfnum »
following is from DavidG on changes and future upgrades
1) Improved slow motion controls and added hand paddle to allows the user to easily slew around the surface of the Sun
2) Added longer singlet focusing mechanism so the singlet can be focused from CaK to Ha
3) Replaced Fecker metal flat with poor polish and flatness on the Ceolostat with a 1/20 wave made from Zerodur. That greatly reduced the scatter and improved the contrast.
4) Found why the Ceolostat was tracking fast for 87 years. The main worm gear has 360 teeth so it needs a 1/8 rpm of the drive shaft. The gear ratio was about 1/7 rpm from calculating the gear ratios in the gear train. The problem was that the pinion gear on the 60 rpm motor had 18 teeth and needed 16 teeth. The math then worked for the rest of the gear train and that resulted in the needed 1/8 rpm that makes the Ceolostat mirror rotate at once in 48.00 hrs. No more RA drift !
5) Made a new eyepiece with better eye relief and more magnifications
6) Made a better grating mount that allows the grating to be per-tilted so we can now reach down to CaK
7) Moved the motor that drives the Anderson prisms to remove any vibration from getting into the image
8) Tested the singlet and slightly stopped it down to mask a slight turned edge
9) Added kinematic feet to the ceolostat plate so it could be critically aligned.
10) Added the pipe baffle to keep anyone from looking into the white light image entering the building.
The future improvements are
I donated three new larger gratings, 2.75" x 2.75" , blazed in the visible, near IR and near UV that we plan add in a few months to replace the 2" x 2" one that I donated and we are using now.
We also just received during Stellafane, 40mm x 40mm Anderson prisms to replace the smaller one which should increase the field of view to about 25% of the Sun.
I also built a solar scintillation monitor that we plan to add to helps us in imaging.
I donated a 1/10 wave 4" Quartz flat that was coated at Stellafane and it will replace the original plate glass steering flat that is about 1/2 wave.
The solar panel will be updated from 35 watts to 235 watts so there will be no risk of draining the batteries during Stellafane.
- Dave
highfnum
Post by highfnum »
thx all
Montana - yes I love the sound of spinning prisms
Merlin66 - is the Meudon/Paris SHS still in action?
Carbon60 - yes seeing an 80 year old device still working and only 4 hrs(car) from where I live so very cool
