My first sun photo
hugo52
My first sun photo
Post by hugo52 »
This is my first serious Solar photo.
I have a Lunt LS60 B600
The ring is 10 times more exposured
Pls advice what can be better(other blocking filter or double stack?).
Regards Hugo
Has thanked: 20819 times
Been thanked: 10489 times
Re: My first sun photo
That's a good start to the world of solar Hugo, welcome to the forum.
Has thanked: 9319 times
Been thanked: 6157 times
Post by ffellah »
Nice first image, welcome Hugo
Has thanked: 8559 times
Been thanked: 8290 times
That’s an excellent first disk, Hugo. Lovely colour too and in my view it’s the way Ha images should be represented. 656.28 nm is red, after all.
Was this taken with a colour camera?
Generally we use monochrome imaging cameras, take an AVI video of a few seconds, use stacking software to produce a single image and apply image deconvolution/sharpening to optimise the image quality. You’ll see lots of examples on this forum.
With my Lunt 60 I generally image with a 2.5x Powermate on a Basler acA1920-155um camera with an IMX 174 sensor to make 4 or 6 pane mosaics. This brings out the optimal level of detail with this aperture.
Welcome.
MAURITS
Has thanked: 2464 times
Been thanked: 4880 times
Post by MAURITS »
Well done Hugo.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17974 times
Been thanked: 8906 times
A very warm and sunny welcome Hugo :hamster: what a wonderful picture to start with, some amazing proms on there :bow
I too like the colour :hamster:
hugo52
Post by hugo52 »
The foto has made with ASI1600 mono sensor 17x13 mm and 3.8um pixel.
Photo is colored with Photoshop.
Next time I will try with powermade 5x
Regards Hugo
https://www.flickr.com/photos/162118128 ... 9470404526
hugo52 wrote: Fri Aug 09, 2019 10:08 am The foto has made with ASI1600 mono sensor 17x13 mm and 3.8um pixel.
Regards Hugo
With that camera i'd go with a 2x barlow, you will get a full disk in one and get good sampling for the pixel size.
pedro
Has thanked: 14 times
Been thanked: 6691 times
Post by pedro »
Welcome to Solarchat Hugo
Starry Jack
Has thanked: 141 times
Been thanked: 240 times
Post by Starry Jack »
Love that giant prom on a full disk!
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
hugo52
Post by hugo52 »
2x barlow, good advice, yes that must improve the optimal filling.
I wil try this first.
Regards Hugo
Astrophil
Been thanked: 581 times
Post by Astrophil »
Nice one, Hugo and welcome.
Phil
Bruce G
Has thanked: 128 times
Been thanked: 121 times
Post by Bruce G »
Much, much better than my first attempt.
About the biggest problem that you have is that there's simply not much to see up there right now.
It looks like you're doing well with the image capture. The rest is all about processing.
Alexandra (Montana) and Mark Townley, and possibly others, have posted very helpful solar imaging guides. They have helped me quite a bit
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Welcome Hugo a great first disc.
Derek
Has thanked: 64 times
Been thanked: 4427 times
Post by MapleRidge »
Welcome Hugo...
You have a good first post with the FD image!!!
Start off slow...get the exposures and camera settings sorted out and then work your way up to barlows. I'm not sure what you have for a mount, but the more you push the camera/scope you will need to have a mount that can keep it all stable too ;) So far the first step looks good!!!
