Which etalon is better? Please, look, think and vote.
Hi all,
I need your little but important help, friends.
Here are two images which were taken not too far apart (in time) from the same location but through two different telescopes and different etalons.
Left image was taken with F/30 (on the etalon) and right image was taken with F/42 (on the etalon).
So, the question: which etalon you rate more narrow and more uniform?
Thanks for reading and your votes.
- 1 vs 2.png (1.11 MiB) Viewed 2484 times
- Been thanked: 8907 times
Re: Which etalon is better? Please, see, think and vote.
Absolutely marginal Valery but I reckon number 2 is slightly better. It is overall marginally more 3D (less flat) and the key for me is the plage to the right of the filament, it is very slightly brighter and more fluffy on the right indicating a tighter bandpass. It is marginal, both are fabulous.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
I agree with Alexandra, number 2 shows better contrast and more detail.
Martin
Martin
- Has thanked: 1192 times
- Been thanked: 1386 times
Re: Which etalon is better? Please, look, think and vote.
Hi Valery,
Would you kindly check out my PM to you on here?
I think the etalon on the left is probably better. My reasons: It's nearly the same as the one on the right, at F42, yet it's doing it at F30. So if they were both brought to F42, the one on the left would be superior and more narrow. I'm specifically looking at the contrast on the fibrils, they're darker, slightly, on the right side image, to me being a little more selective and narrow band, just like filaments will be darker in that sense. Yet the F30 image is doing nearly the same thing, just nearly, at only F30. So if it were brought up to F42, it would likely be better. Uniformity seems to be essentially equal, everything looks onband in the same locations. There's a little super granulation peaking through on both maybe, to be expected with a single etalon like this.
- Been thanked: 4981 times
Valery:
I like better the first one. (F/30)
I agree with Marty.
I agree with Marty.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4881 times
Valery, I like the first,
It is indeed marginal between the two images, but in the first image I see some finer details in the middle field.
- Been thanked: 3 times
Hi Valery, After looking carefully,in my opinion the first one is more appealing,and has very slightly better definition. Though there is not a lot to of difference, probably a personal choice. I just wish my scope would be that good !!!! John.
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
I also prefer the first (left) image, better contrast and more detail can be seen
Pedro Re'
- Has thanked: 20828 times
- Been thanked: 10502 times
Both look essentially identical to me Valery, there are small differences, but is not night or day. If one can do it at f30 then to me that is better than f42, just on the grounds of shorter exposure and better sampling.
Thanks to all who expressed his opinion.
How do you rate the etalons Valery?
My conservative estimation is that they are better than some expensive and larger 0,3A etalons.
