A nice solar show today. Some proms and AR 2752 is still active although less energetic than yesterday. Both images were taken using the LS80 DS and PGR Grasshopper cameras. A 5x Powermate was used for the close up shot.
Phil
Nov. 19 Disk and AR
- Has thanked: 17572 times
- Been thanked: 16691 times
Re: Nov. 19 Disk and AR
Very nice Phil! Your images show considerably more than I could pick up visually today. I could not see the AR at all.
- Has thanked: 20424 times
- Been thanked: 10243 times
Great images, nicely tuned double stack system!
- Has thanked: 8415 times
- Been thanked: 8161 times
Nice to see some activity, Phil. Lovely FD.
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4786 times
- Has thanked: 17667 times
- Been thanked: 8787 times
- Has thanked: 9144 times
- Been thanked: 6025 times
Excellent images, Phil.
Thanks for sharing.
Thanks for sharing.
Thank you all for the kind comments. They definitely boost enthusiasm and motivation this time of year and when solar activity is low. James, sometimes the camera can be adjusted to see more than I can. Processing helps as well. Mark, I reset the pressure on the etalons and must have gotten lucky with the tuning. Honestly, I still have trouble finding the center wavelength visually. Alexandra, after your transit ordeal, I hope you get some clear skies soon. Franco, The full disk was processed without a flat. I had changed the ROI size and the flat frame would not load. Maybe for the best. Stu, Maurits, and Valery, Much appreciated.
Phil
Phil
