Some tests with double stack etalons (mica & FS) and the C8 EdgeHD
- Has thanked: 1 time
- Been thanked: 2725 times
Dear All,
Here are some tests I made last August with the C8 EdgeHD at F/35 and a double stack combinaison consisting in a DayStar PE 0.6 A and a Coronado SMN35 0.5A.
As a reminder, the Coronado SMN35 0.5A is a fused silica etalon made at the begining of Coronado when David Lunt was experimenting different options for the manufacturing of etalons. Too bad there were only a handfull made.
The advantage is the excellent transmission (compared to mica-spaced etalons) and larger refractive index (compared to air-spaced etalons).
It makes it possible to double stack the PE 0.6 A and the SMN 0.5A, while keeping a reasonnable exposure time.
As a comparison, the contrast of the 0.6A + 0.5 A combination is much higher than the SolarSpectrum 0.3 A.
No need to say that the tuning of the center wavelength of both etalons is a bit tricky. I am still probably a little bit away from the center of Ha here.
Here is an image of the North Pole :
Somewhere on the disk :
Somewhere else :
I tried an animation over a 43 min period, with 1 frame /min. It is a very shaky. One image/30 s would certainly have been better. Still, it shows that even when there is nothing much on the Sun, it is still very active in Ha.
Clear skies !
Somewhere else :
Clear skies !
- Has thanked: 1200 times
- Been thanked: 1391 times
Re: Some tests with double stack etalons (mica & FS) and the C8 EdgeHD
Really nice Christian,
I wonder though, why the double limb persists with the two etalons?
Do you think this could be done with one etalon and a reasonably narrow blocking filter (1A to 3A)?
This is an interesting question Marty.
Indeed, the double limb effect depends on the rejection of the photospheric light and also on the resolution of image.
The double limb effect is less visible when the resolution is lower (the contrast of the photopheric limb is lost). There are some very interesting images taken by professionals (and large telescopes) where the double limb effect is still visible while using narrow bandpass.
Thanks Christian, the resolution you have there is truly impressive. It's why I wondered, versus how tricky it is to tune two etalons together in such a configuration to begin with, under such resolution. Must have been incredible seeing! Thanks for sharing!
Interesting test and superb images, Christian.
Phil
Phil
- Bob Yoesle
- Has thanked: 543 times
- Been thanked: 812 times
Hi Christian,
Very nice images! ;-)
I'm thinking one or both of the filters is slightly off-band, and hence the double limb is still present. Alternatively, even at f35 you may not be getting the theoretical 0.5A and 0.6A FWHM of either filter, especially if your telecentric optics are not optimized for the C8 Edge HD.
Frankly, I suspect some professional astronomers wouldn't necessarily be that concerned or perhaps astute about the dialing in of their filters to notice they aren't exactly on-band either, or that their equipment might not be properly optimized. At these narrow bandpasses, even minor mis-adjustments might affect tuning, etc.
In my experience, two ~ 0.7A FWHM SM90 filters have enough resolution to show little if any hint of parasitic continuum leakage/double limb:
I also note the tell-tail hi-res "spiky" appearance of the dark mottles on your images of the chromospheric disc, similar to the image below + 0.5 A off-band:
Note also the dark narrow band lying right above the photospheric limb in your first image. This is very similar to that noted by Bray and Loughhead for the - 0.75A image in Plate 2.8 (a) below:
Bray and Loughhead, The Solar Chromosphere, 1974.
- Has thanked: 20962 times
- Been thanked: 10593 times
Excellent image Christian, I agree with Bob, you're slightly in the red - not that this detracts from your images, I think they look great. Any chance of a few pickies of the Coronado etalon, not come across one before.
Useful info too thanks Bob.
- MAURITS
- Has thanked: 2501 times
- Been thanked: 4928 times
Unbelievable beautiful images Christian.
- Has thanked: 65 times
- Been thanked: 4462 times
Christian...
The images you posted through the C8 Edge look amazing...be they a tad off band or not
The additional images and comments in the thread are very informative too.
Hi guys,
Thanks for your interesting comments.
Here are some examples of solar limb images taken with large professional telescopes.
The first one is from the VTT, with a double-stacked etalons in collimated beam.The FWHM is 0.043 A (no mistake ...):
Source : K.G Puschmann et al, The new Göttingen Fabry-Pérot spectrometer for two-dimensional observation of the Sun. A&S 451, 2006.
There is still some hint of the solar limb at the line center.
The CRISP double-stack etalon (on the STT) has less parasitic light, even if the FWHM is "only" 0.06 A (telecentric beam):
The limb is very faintly visible at + / 0.6 A from the center line, and more readily visible at +/- 0.8A.
BTW, at F/35 and in a telecentric beam, the mica-spaced 0.6A has an effective FWHM of 0.65 A, while the effective FWHM of the 0.5 fused silica about 0.6A :
At the end of the day, I'll have some more tests to do when the Sun is back and highher to actually tune this thing on the center line
- Been thanked: 5016 times
Christian:
Super images and information.
Thanks for sharing.
Thanks for sharing.
Nice images, Christian!
BTW Can you, please, show us this Lunt etalon?
- Bob Yoesle
Very nice references Christian :-)
Bray and Loughhead noted the photospheric limb begins to manifest itself at +/- 0.65A off the center line, which seems to be essentially confirmed and refined by the higher resolution SST CRISP double stack to be +/- 0.6A. They also noted - and the CRISP images clearly show - that the "general chromosphere extends above the average spicules... Thus the popular view that spicules rise above the chromosphere is incorrect, except insofar as the macrospicules are concerned." Therefore, it is wholly inaccurate to describe the double limb of an on-band image as the "spicule layer."
The lower resolution VTT "line center" image indeed seems to be at odds with the other two sources in showing the narrow band at the photosphere limb...?
Here's a link to an IOM FS SMn series filter - and interesting related discussion:
https://www.cloudynights.com/topic/5970 ... try8244890
- Has thanked: 177 times
- Been thanked: 429 times
Those are awesome images, Christian! The annotation says 0.4 arcsec seeing. If you commonly get that kind of daytime seeing, I wonder what a C14 would show.
I agree that with those two filters double stacked and centered, you should eliminate the double limb. If not, then something else is going on. Like leakage on a side spike through the blocking filter. If the space between spikes (FSR?) on one filter is narrower than the blocking filter is made for, then high transmission on that one could get through the high shoulders of the other enough to cause a double limb. Not sure what the spacing is for the Coronado SMN35.
- Has thanked: 18105 times
- Been thanked: 8942 times
These are superb images Christian, I am really looking forward to seeing more from this pair in the future. Lovely crisp images too
- pedro
- Has thanked: 14 times
- Been thanked: 6754 times
fantastic images Christian, nice info as well
Pedro Re'
Oops. Never mind about this idea. Going through some old correspondence, I realize that the SMN35 is a complete unit, like a DayStar or a SolarSpectrum, so the correct blocking filter is integrated into it. The owners were very happy with it.george9 wrote: ↑Mon Feb 03, 2020 4:18 am I agree that with those two filters double stacked and centered, you should eliminate the double limb. If not, then something else is going on. Like leakage on a side spike through the blocking filter. If the space between spikes (FSR?) on one filter is narrower than the blocking filter is made for, then high transmission on that one could get through the high shoulders of the other enough to cause a double limb. Not sure what the spacing is for the Coronado SMN35.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Great Images Christian, actually the whole thread is amazing I really appreciate all the technical information, many thanks for all this information Christian and Bob.
Martin
Martin
Thanks to all :-)
Here are some pictures of the SMN35 :
- on the left, the fused silica etalon in its oven,
- on the center, the ITF filter (from Beloptik),
- on the right, the BF with 2 A FWHM on a very astute rotating tilt system.
When stacked on the DayStar 0.6A, I use only the fused silica etalon part (left side).
Georges, the FSR of the etalon is 10 A. Accordingly, the spikes of transmission are blocked by the DayStar etalon and its BF (well, I guess so ...).
In this view, we can see how transparent is the fused silica etalon. It is difficult to make the difference between the window plates and their reflections.
The tricky thing is that the temperature setting is through a very small screw that is difficult to access, and without any reference position ...
Christian, yes my original blocking filter (for an ASP60) was also 2A (Prom15T), not because it needed 2A but I think because they simply repurposed their old prom filter. Nevertheless, if after tuning you still see a double limb, I would just try the 2A blocking filter and see if it eliminates it. (I am assuming that each one individually looks about right.)
Of course the image looks great even with the limb.
Christian,
I believe you can do the following - use only the secondary etalon with it's BF and Trimmer and in combination with a telecentric you do use. Adjust the the image to the best contrast (or better for the lowest brightness with histogram as a reference). Then install the secondary etalon behind the main DayStar etalon and adjust the DayStar for the maximal brightness in the DS combination. You should be really very close to the best match of the two etalons CWLs.
