Re: Sun in Ha and Ca II K, September 9th '20
- Has thanked: 8559 times
- Been thanked: 8290 times
A few from this morning in Ha and Ca II K.
First up is a full-disk on a DS Lunt 60 in mono and colour. Captured on a Basler acA1920-155um camera and 1.5x Barlow
20200909_Ha_FD_Mono by Stuart Green, on Flickr
20200909_Ha_FD_Colour by Stuart Green, on Flickr
Calcium K FDs captured on a 72mm f6 refractor using a Basler acA2440-75 camera, 1.5x Barlow and Lunt B600 Ca K module with omega/calcium K-line combo.
20200909_CaK_FD_Mono by Stuart Green, on Flickr
20200909_CaK_FD_Colour by Stuart Green, on Flickr
And some closer views on a Tecnosky 125 mm f7.8 refractor using a Basler acA2440-75 camera, 2.7x Barlow and Lunt B1800 Ca K module
with with and without additional filters (omega and Calcium K-line).
First without the additional filters:
20200909_CaK_x2.7_Mono_LuntB1800 by Stuart Green, on Flickr
20200909_CaK_x2.7_Colour_LuntB1800 by Stuart Green, on Flickr
and with..
20200909_CaK_x2.7_Mono_LuntB1800_Omega by Stuart Green, on Flickr
20200909_CaK_x2.7_Colour_LuntB1800_Omega by Stuart Green, on Flickr
Thanks for looking.
and with..
Thanks for looking.
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: Re: Sun in Ha and Ca II K, September 9th '20
Very nice images Stuart. The full disc CaK images show the plage in the south that contains new pores very well. The Ha images give me a good idea what is going on today. Thanks.
- Been thanked: 4900 times
- Been thanked: 8906 times
Hmmm that baffles me Stuart, I can't understand why the Lunt filter on it's own the granulation cells are very large and flat disc shaped. Whereas with the Omega filter they suddenly become extremely small and dotty? I didn't think CaK was tiny dots, I thought it were photospheric like reverse granulation cells? Unless in the CaK on it's own you are seeing this, then by adding in the Omega filter you are actually seeing higher in the Chromosphere and seeing spicules instead of granulation cells?
Do you have any thoughts?
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
A very quiet sun, but interesting captures nonetheless. I'd also be interested in trying to understand the point Alexandra raised.
- Has thanked: 9319 times
- Been thanked: 6157 times
A beautiful series Stu. Those Ha disks are so evenly illuminated. Hoping that activity will pick up again soon before the sun starts to be lower on the horizon.
- Has thanked: 174 times
- Been thanked: 619 times
Stu, sorry to high-jack the thread.....
Alexandra,
Interesting question...
My CaK DIY (three Omega filters + PST Cak "yellow") always seem to give "sharper" contrast features compared to others. I'm using the ASI 1600MM and sampling at 0.79 arcsec/pixel. My seeing is pretty average to bad.....
I use Firecapture, AS3! and a gentle tweak in ImPPG.
I always put it down to the effects of reducing the image to around 800 x 800 pixel (from 4656 x 3520) for suitable upload sizing.
The two attached images: one is a full frame JPEG from the full frame TIF (I can't seem to be able to upload an original TIF file???) and the other a reduced JPEG. (EDIT: Uploaded the original TIF file to dropbox: https://www.dropbox.com/s/pzkp539a8bjyf ... l.tif?dl=0 ) (What I should do is test the CaK DIY filter bandwidth on the spectrograph.......)
Alexandra,
No problem, Ken.
Many thanks everyone. I’m going to re-run with and without the additional filters multiple times to see if the effect is consistent as seeing and processing can significantly affect the look of the output image. This weekend looks promising weather wise.
- Been thanked: 4980 times
Stu:
A beautiful set of images.
Best wishes, hope that you will get nice weather, at my place it is daily clouded and rains.
- Has thanked: 20819 times
- Been thanked: 10489 times
Nice images Stu. I've no time to get online at the moment, let alone do solar. Need life to drop down a gear...
Many thanks Eric and Mark.
Sounds like you’re really busy, Mark....back to school.
Stu,
Did you get the chance to try the various filter combinations?
Ken
Ken
Hi Ken,
Unfortunately not. The seeing conditions haven’t been suitable for a fair and accurate comparison. Okay for FDs, but nothing more. It is something I need to do when conditions allow.
