I currently have a ZWO 178MC OSC planetary camera. Everybody tells me that I need to get a mono chrome camera for solar imaging.
I have narrowed it down to two cameras the ZWO ASI178MM or the ASI174MM. The ASI174MM is quite a bit more expensive and I am not sure why?
I have a Lunt 60MM HA f/7 Solar scope and looking for recommendations.
Which Camera for Lunt 60MT
- Been thanked: 4900 times
Re: Which Camera for Lunt 60MT
Using https://astronomy.tools/calculators/field_of_view/ shows the different Field of View of both the cameras you mention here.
I have the Lunt 60 Ha and Cal-K scopes using the ZWO ASI 178MM mono cameras which give the Full Disk availability without the need for further magnification albeit I can magnify into specific FD regions if required using 2x Barlows/extenders etc.
Whereas with the ASI 174MM - you can see a much wider-field of view and to get closer you will need to use those Barlow type magnifiers...
Colouring of mono-camera imaging of the Sun takes place during the subsequent processing - to ones own desires..
Take a few minutes to try-out that web-link with the various options within it, to see the results which suit you best.
Best Wishes
Best Wishes
- Has thanked: 20962 times
- Been thanked: 10593 times
Hi there,
The 178 is suited to full disk shots, the 174 to closeup shots.
