Earth-Sun Scaling tutorial & Images” written by “krakatoa1883
Moderator: marktownley
MAURITS
Has thanked: 289 times
Been thanked: 636 times
April 14 Evolution ...
Post by MAURITS »
A serious evolution between today and yesterday, with a beautiful "arch" forming on this prominence.
ASI 174MM camera with interference eliminator.
Quark Chromosphere
TOA 150-B with Baader DERF.
09_45_47 Gray Black.jpg (208.03 KiB) Viewed 531 times
09_45_47 Gray Earth.jpg (695.15 KiB) Viewed 531 times
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
krakatoa1883
Has thanked: 131 times
Been thanked: 428 times
Re: April 14 Evolution ...
Post by krakatoa1883 »
Very good images with much details in the spicule carpet, my Quark Chromo is not so good. Is the interference eliminator needed with the 174 ?
banjo
Has thanked: 362 times
Been thanked: 536 times
Post by banjo »
Sans titre 1.gif (10.9 KiB) Viewed 511 times
superbe, bravooooooo !!!!
MAURITS
Post by MAURITS »
krakatoa1883 wrote: Wed Apr 14, 2021 3:00 pm Very good images with much details in the spicule carpet, my Quark Chromo is not so good. Is the interference eliminator needed with the 174 ?
Raf, without de eliminator I have NR's with the 174MM.
Maurits
Has thanked: 1562 times
Been thanked: 885 times
Post by ffellah »
Excellent images Maurits. The prom came out really well.
arnedanielsen
Has thanked: 367 times
Been thanked: 343 times
Post by arnedanielsen »
Excellent closeup images, Maurits!
Arne
Martin_S
Has thanked: 170 times
Been thanked: 585 times
Post by Martin_S »
Great Prom detail Maurits, thanks for sharing your images.
Martin
H - alpha setup
White Light setup
Skywatcher ED72 ,100 f/10 Achromat Homemade solar wedge, IR cut filter, #58 green filter.
AZEQ5 Pro mount.
Darkside setup
Skywatcher ED72AZGTi mount , GSO RC6. Celestron Evolution mount
Stardust5858
Has thanked: 533 times
Been thanked: 709 times
Post by Stardust5858 »
Lovely images Maurits. Thanks for sharing
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Has thanked: 4445 times
Been thanked: 1888 times
Wow!! this is a gorgeous shot :bow :hamster:
That is one thing I should learn, how to get an Earth on a picture. The biggest downfall for me is that I have never found a decent Earth picture to use and how you get it so small without it being one big pixel?
Boso36
Has thanked: 119 times
Been thanked: 102 times
Post by Boso36 »
Hi Alexandra,
I think this Earth may be reasonably easy to use. I already isolated the Earth, its 673 pixels. I could explain it to you, but I have plans to make a Solar SSM ! I could publish it another time on the tutorials section.
There is some information on Brierley Hill solar blog, although I found the sound very hard to hear and understand.
https://brierleyhillsolar.blogspot.com/ ... rials.html
I had to learn Photoshop, layers and everything. Still not learned it al! after more than 2 years ! You can also use GIMP or Affinity Photo, which are less expensive alternatives and quite adequate.
I only found it after an extensive search online.
Magnus
Earth-673pixels-scale.tif
Earth-673pixels-scale.tif (1.32 MiB) Viewed 447 times
Thanks Magnus
Boso36
Post by Boso36 »
Maybe this is easier to see/use.
But it doesn't have the UK on it :lol:
MAURITS
Post by MAURITS »
Montana wrote: Thu Apr 15, 2021 7:02 am But it doesn't have the UK on it :lol:
Alexandra, I have the "TIF image" that I use in my images as above.
You can use them, can I set it up here as a TIF file?
Maurits
Thanks a million :) TIFs aren't displayed in the forum but you can right click and open them :)
MAURITS
Post by MAURITS »
Earth.tif
Earth.tif (12.71 MiB) Viewed 427 times
Maurits
Much better, the centre of the universe :lol:
We are just short of the Australian side in the collection now :)
Boso36
Post by Boso36 »
Alexandra,
Maybe this is better for you. It has the UK near the centre...
earth-uk-isolate2.tif
earth-uk-isolate2.tif (1.91 MiB) Viewed 414 times
Boso36
Post by Boso36 »
Hi all,
I think I have found an easier way to calculate the size of the earth (in pixels) - this will be an option in your imaging program - to resize the earth image. Assuming the diameter of the earth is 109 times smaller than the sun, and the sun is about 30 minutes of arc = 1800 arc seconds.
Then just calculate your image scale using the calculator in:
astronomy.tools
(make adjustments for your optical train) - once you have this reasonably accurately: then (image scale is in arcseconds/pixel).
size of earth (pixels)= 16.514/(image scale)
This will save you the hassle of having to draw a large circle in photoshop, measure the diameter of the sun in millimetres and dividing it by 109 to get the diameter of the earth.
I am sure this has been done before, but not able to find a reference to it.
If I am wrong, then please correct my error(s).
Hope this helps.
Magnus
EGRAY_OBSERVATORY
Been thanked: 2172 times
Post by EGRAY_OBSERVATORY »
Two excellent images Maurits of the prom showing fine detail
Thanks for sharing
Regards
Has thanked: 37 times
Been thanked: 117 times
Here's an Aussie version.....
small earth_132pix.jpg (31.02 KiB) Viewed 279 times
Placed in Library for reference.
