ImPPG version 0.6.3
GreatAttractor
Has thanked: 169 times
Been thanked: 109 times
ImPPG version 0.6.3
Post by GreatAttractor »
Download from: https://github.com/GreatAttractor/imppg ... tag/v0.6.3
Enhancements:
- Opening an image file by dragging and dropping onto the ImPPG window
Bug fixes:
- Crash when batch processing in CPU mode with deringing enabled
My software:
My images
Has thanked: 1852 times
Been thanked: 1666 times
Re: ImPPG version 0.6.3
Many thanks for all your great work developing this software.
It really is very much appreciated.
EGRAY_OBSERVATORY
Been thanked: 1940 times
Post by EGRAY_OBSERVATORY »
Also thanks from me for your efforts in developing this version.
I hope to start using it soon.
Best Wishes
Been thanked: 389 times
Post by christian viladrich »
A big thanks for this very nice software !
Christian
Has thanked: 4076 times
Been thanked: 1672 times
:bow :bow :bow
Has thanked: 469 times
Been thanked: 460 times
Post by MalVeauX »
Huge thanks for keeping this going, great software, the GPU optimization was such a huge leap!
Rusted
Has thanked: 1653 times
Been thanked: 415 times
Post by Rusted »
A huge thank you from me as well. :bow
ImPPG is the only software which will save the day in poor seeing conditions.
Today was a perfect example: Same image: Before and after ImPPG:
Capture 2021-04-26T16_06_07_l3_ap4680.jpg (24.3 KiB) Viewed 267 times
26042021 16.06 no gpc.jpg (55.62 KiB) Viewed 267 times
EGRAY_OBSERVATORY
Thank you Chris and I will now try my latest of the same regions as yours, to see what it does for me..
Cheers
EGRAY_OBSERVATORY
Ok a few minutes later than my previous here - with a basic-start to a posted-image since redone with imppg and for a start is a welcome improvement.
Will do more trials with any different settings available in imppg.
Thanks for the reminder Chris and of course Filip/GreatAttractor - Thanks Very Much.
26-4-2021 1609z TV2.5x 200frames AR2018-2021.jpg (52.34 KiB) Viewed 258 times
Rusted
Post by Rusted »
Your ImPPG version is over-sharpened. Leading to uniform and unnatural artefacts.
ImPPG should ideally be used just after your stacking software.
EGRAY_OBSERVATORY
Thank you Chris and yes this was done in a hurry and is still in the leaning and experimental stage of use.
Last night was a very-busy time for me with lots to do's...
Cheers
Boso36
Has thanked: 119 times
Been thanked: 102 times
Post by Boso36 »
GreatAttractor wrote: Thu Apr 15, 2021 7:21 pm Download from: https://github.com/GreatAttractor/imppg ... tag/v0.6.3
Enhancements:
Bug fixes:
Hi Filip,
Thanks for the great work on this software.
:band
I just wonder about the following things.
1) Can you specify LRD separately from unsharp masking ? I mean I would like to do one with out necessarily doing the other.
2) Can you include a histogram display feature ? I think having a histogram would be advantageous. I hope you can do this for the next update !!
Thank you.
Magnus
GreatAttractor
Boso36 wrote: Tue May 04, 2021 2:50 pm 1) Can you specify LRD separately from unsharp masking ? I mean I would like to do one with out necessarily doing the other.
Done and done ;)
1) Both can be disabled independently. To disable L-R deconvolution, set the number of iterations to 0 (or just click the "disable" button). To disable unsharp masking, set the "amount" to 1.0 (values > 1.0 sharpen, values < 1.0 blur), or just click "reset".
2) Histogram (of the current selection) is displayed in the background of the tone curve window. It applies to the image after all processing steps BEFORE the tone curve application.
My software:
My images
Boso36
Post by Boso36 »
GreatAttractor wrote: Tue May 04, 2021 3:36 pm
Done and done ;)
Thank you Filip,
I shall have to read the manual again for ImPPG.
On another note, the Tone Curve editor seems to have disappeared. How do you get it back ? It happened before a long time ago now.
Many thanks.
Magnus
Boso36
Post by Boso36 »
Hi Filip,
I found the Tone Editor reset window position command.
I will have to learn ImPPG again now !!
Magnus
