DIY Solar Scintillation Seeing Monitor with FC support
rsfoto
Has thanked: 2657 times
Been thanked: 1985 times
Re: DIY Solar Scintillation Seeing Monitor with FC support
Post by rsfoto »
I have to start all over again as it looks like I fried my LMC6484 due to improper measuring while the Arduino was running. The values from yesterday where too low and so I tested the circuit which I still had on my breadboard and they looked much more logical.
Also the idea of the 3 capacitors un paralel was not good. I finally got my 3.3 uF capacitors and exchanged and it stabilized.
Well I still have holidays and so no problem. At least I have something to do.
saludos
PDB
Been thanked: 63 times
Post by PDB »
Ooops, can happen. Few months ago i fried a nano Arduino in my focus controller while doing some modifications.
regards,
rsfoto
Post by rsfoto »
Yes, " Sh...t happens " and I should have used a socket instead of Hot soldering the LMC6484 onto the board
Well makes me have more experience for the future :seesaw
rsfoto
Post by rsfoto »
Went back to the bread boarded circuit and added a LED Bar for the visual identification while the SSM is working.
Video of 1 minute which crunches a real time video I took during 18 minutes.
https://vimeo.com/249602522
Below the circuit on the bread board
:seesaw
banjo
Has thanked: 286 times
Been thanked: 443 times
Post by banjo »
:bow :bow
a few colors here ;) ;)
https://vimeo.com/249800318
rsfoto
Post by rsfoto »
banjo wrote: Fri Jan 05, 2018 1:25 pm Hello,
:bow :bow
Hi Paul,
Is that in real time and are you reading at an iteration rate of 1000 ? I am just starting and learning to program the Arduino so I still have a long way to go.
banjo
Post by banjo »
no it's just a simulation before integration into my software, I find that the colors are more meaningful than the numbers.
blue very good
green ok
red useless
a small gift of January 5 :lol: , not very stable, the sun is low and the wind is very strong in France :mad: :mad:
rsfoto
Post by rsfoto »
banjo wrote: Sat Jan 06, 2018 10:47 am Hello,
blue very good
green ok
red useless
Thank Paul and yes you are right. My bar when many LED on is bad and few LED on good. At the beginning it is difficult to judge but with the time one gets used to it.
LED 1 and 2 I use them for signalizing Sun intensity
Led 1 Sun intensity and > 0.5 to <=1.0 then OK and ON else OFF
LED 2 blinks when Sun intensity > 1.0 abs so I know I have to adjust. It happened to me that I had to readjust because the adjustment the day before was again to high and as I see the sky today I think I have to readjust.
The little BPW34 was delivering yesterday up to 3 mA ( 3000 uA ) of current.
and then LED 3 to 10 are as following
LED 3 -----------< 1.0
LED 4 > 1.0 --- < 1.5
LED 5 > 1.5 --- < 2.0
LED 6 > 2.0 --- < 2.5
LED 7 > 2.5 --- < 3.0
LED 8 > 3.0 --- < 3.5
LED 9 > 3.5 --- < 4.0
LED 10 > 4.0 ----------
PDB
Post by PDB »
:bow :bow
Excellent idea!!
immediatelly started working on my Solar Monitor again
Now still someting similar to add for input value
banjo
Post by banjo »
Hello everyone,
Paul, that's exactly what I would like to do, bargraph input & output super.
Your software is extra !!
Is it possible to have it?
PDB
Post by PDB »
Yes it is possible but this version is not completely ready yet ... and only Linux at the moment, although I am working on a port to Windows (would like to port it on OS/X as well, but no machine, and think my wife will throw me out if I buy yet another computer ;) )
I will let you know when it is ready and tested. The automatic trigger of video capture will (should) work wit Planetary Imager and FireCapture.
banjo
Post by banjo »
thank you Paul,
I am with Win7 and do not know much in programming.
I'm waiting for your final version with pleasure.
PDB
Post by PDB »
banjo wrote: Sun Jan 07, 2018 10:07 am Hello everyone,
Paul,
have sent you a private message about this. (A windows test version is now available)
P.
banjo
Post by banjo »
Hello everyone,
thank you for this message, sorry not to have answered before, I'll try as soon as the sun will show.
In the south of France just December 5th and January 5th really good, if not only rain and clouds.
Has thanked: 27 times
Been thanked: 105 times
Any updates on this project?
Any changes/ improvements over the past three years?
Boso36
Has thanked: 119 times
Been thanked: 102 times
DIY SSM Arduino pdf file please upload ?
Post by Boso36 »
Original file for DIY SSM - https://www.ecu.edu/cs-cas/physics/uplo ... final2.pdf
I can't find this now, can anyone please upload this, as I want to pursue this project for myself ?
Many thanks
Magnus
PDB
Post by PDB »
suppose you mean this?
Never trust the cloud to keep data ;)
An-Inexpensive-Solar-Scintillation-Seeing-Monitor-Circuit-with-Arduino-Interface-final2.pdf
(604.24 KiB) Downloaded 25 times
Boso36
Post by Boso36 »
PDB wrote: Mon Mar 22, 2021 11:41 am suppose you mean this?
Hi Paul !
Thank you very much Paul. You saved me a lot of work and research.
Great !
Magnus
Boso36
Post by Boso36 »
Merlin66 wrote: Fri Jan 22, 2021 10:23 pm Any updates on this project?
Hi All,
I am starting to tackle this project and build my own DIY SSM. Does everyone use one or would like to own one ?
I wonder what percentage of solar imagers actually use a SSM connected to FC or not connected to FC (FireCapture)?
I am thinking if someone could build it, would some of you be interested to buy it if it was a lot less expensive than the ones made by the mainstream company for 350 dollars/euros?
Magnus
Has thanked: 4483 times
Been thanked: 1979 times
I have an SSM, used to use it connected to FC, rarely use it now, just gauge the seeing by eye and experience.
Boso36
Post by Boso36 »
marktownley wrote: Tue Apr 27, 2021 6:14 pm I have an SSM, used to use it connected to FC, rarely use it now, just gauge the seeing by eye and experience.
Thanks Mark,
That is very interesting. Sort of tallies with what I can tell from my own eyes. I am getting better with experience.
I will see if I can build one inexpensively, could be fun ?
Magnus
